Mezmerize B1 Buffer Preamp
mounted on a 4mm ally sheet with the heat sinks glued .
going for r /set single 10R per side
diyAudio Chief Moderator
Joined 2002
Its counter-intuitive but its right. Has to do with increased VGS (due to more current) reaching nearer to the three LEDS combined VF. That VF-VGS difference is what you measure across the setting resistor. Despite ~0.3V Vref loss you went from 60mA to 163-174mA now.
Joined 2002
Most builders were historically happy enough where you now stand as it was discernibly better than with 60mA when further on it just gets gradually better. That was with bigger transformer and Hypnotize single input version which had more reservoirs. With your transformer and a Mezmerize try down to 5 Ohm I would say and judge for yourself. Piggy back another 10 Ohm on each Rset is the easy way. Monitor your rectifier diodes temperature also.
Hi -- I'm also building the Mez B1, and just got to listen to music through it for the first time today! Beautiful.
Here's a quick picture of where I got today. As you can see, there's space for an internal DAC streamer which will go in there next, as soon as I get the PSU boards from Teabag. I'll post more/better pictures when I'm done.
I could not have gotten this far without this forum and all your advice, so thank you all for that, and thank you to Salas for designing this beautiful piece.
