Meridian Tuner 204
Hi There
i've got same issue here - did u replaced only the both SAA's ? or is the display module also affected ? (i have a newer design on PCB, do not need to unsolder it for IC change)
- what should i check before i plug the Mains?
thanks for any help, Mitsch
Yep,
my Meridian 204 tuner is also working again, but it was more then just the Battery to replace...it was:
key driver chip, display driver chip and even CPU!
i have a scheme as pdf if anyone needs it...
CPU: if there is something like in between Hi and Lo (+/-3V) on Busses, it has to be replaced...
a fine tuner who is worth to be repaired...i like it, but if anybody wants it, i cold even sell it...
stay FM!
scheme!
this is what may help! good luck! sorry, no rc- codes...
Yep,
I have a scheme as pdf if anyone needs it...
Many Thanks SMITSCH for your contribution ( your schemes ).
My Meridian is out of order :
- display panel with erratic functions
- battery NiMh < 0,5 volt
I will do changing to solve ( hope it the reason of troubles ).
Raymond
Meridian 204 FM Tuner - RF Input is loose, need screw type, and possibly a pin
Hello,
I love my Meridian 204 FM Tuner (and 508.20->.24 CDP).
My RF Input is loose and I disassembled the unit and a screw and pin appear to be missing.
Could someone please check their 204 and tell me what the screw type, thread type/pitch and if there is a pin to the left of the RF Input, and if so what size the pin might be?
I’m new and appreciate all the help from fellow audio enthusiasts.
Thank you, K
