Memphis 16-pr1x1000 help
not positive just burnt, and the resistor was still withing tolerance, The top pad (single leg of the p8) other than to the resistor? not connected is however i replaced it. i have replaced the ic and drivers and all outputs, when i put it on resisted current, i get while on chassis ground, i cant seem to get the correct readings?? they change, i really need help...
Q206 1:-11.92v 2: 3.42v 3: -14.56v
Q207 same
Q107 " "
Q106 " "
Q205 1: 4.83v 2: 15.98v 3: 7.84v
Q206 " "
Q104 " "
Q105 " "
i changed the regulator the resistor is within tolerance, i dont have the kia 7815af yet, i have some of those small capacitors that are 20% 100uf 16v? im not sure how i can test them or the kia component. i have not tested for audio as of yet, i didnt leave it powered up long.
This small smd capacitor.
I got a new board for a early repair I never completed. All the mosfets and trace was ripped from the board. I nightmare of repairs. So I installed everything 3205's in the ps. it was up and running great, alone. Installed the the output transistors 3amps of current. New drivers and a ir52092s, brought the current down. But I have a -4.5vdc on the speaker output.?
