sugested bracing
Any measurement for the bracing.
this wil fit in a 400 ltr cab.
haven't tought about a fold yet.
th don't agree much with these mcm.
2 mcm in series
Why would you want a 400l cab with a horn that is 4m long just for 95dB to 40Hz?
check post 76Why would you want a 400l cab with a horn that is 4m long just for 95dB to 40Hz?
its 97.5 db@ 35 hz@2.83 volts with only $60 ,- of speakers in a 380 ltr cab.
with 4 thats 108.5 db from33hz up
not bad at all imo
see what i can do
edit/use this one
I went to home depot to this morning to check out there plywood. There plywood look cheap and weak , Would check lowes but too far to travel.
i think its best if you draw the horn flare on the side pannels and measure from there
if the pannels are 12.2 or 11.9 they might not fit exactly.
maybe you can make them from left over strips of wood ,they dont need to be in one piece.
the bracing is just a sugestion of how it "could" be done.
yes you can ,but let me put some pro's and con's here
*a lot more weight to carry around.
*wood is much more expencive (same grade)
*$/db rate is going in the wrong direction.
*i have to redisign all(i don't mind but you have to be patient.)
*look@ the pic here this a verry solid construction even with 1/2 ply
with all the bracing as sugested i think it wil be fine (think of jbells ss15 uses also 1/2 ply)
however ,you could make the back,bottem,horn mouth and side pannels 3/4 ,but id wil ad cost and weight.
and then there is wood and wood, fi. 1/2 bb ply vs 3/4 underlayment.
I would love to used the 1/2"plywood butnone of the lumber store didn't bring any good quailty plywood.
i know using 3/4" ply will make the cabinet havier and cost more.
Few months ago i got a tapped horn plan from lilmike and could not build it because the plan was design for 1/2'' plywood and none of the stores bring good quailty.
ok i will wait.
can the redesign be done in Inches please
I will keep looking around maybe i will get lucky, anyone from the nyc area know where i can get some good quailty plywod.
i want to get one build and listen to before winter start.
wel plywood is prefered.
but you could use 1/2"mdf for the first part of the horn,and make the outside panels 18mm underlayment.
Thanks epa sound like a good plan
Yesterday I went to lowes there 1/2 arauco ply is $35.00 a sheet and the 3/4" arauco ply is 40.00 a sheet. To be honest I rather the 3/4" ply than the 1/2" ply.
The 3/4" ply look and feel stronger.
Not to take things too off topic but I
like the look of that ported enclosure kornnylike; what are the dimensions? How does it sound?
-David
Did test it yet
I can post the plan later if you want
- Subwoofers
- Mcm 8" 55-2421 Ts parameter
