Matti Otala - An Amplifier Milestone. Dead or Alive
Often people make no distinction between good or bad amps, or preferred or not preferred amps.
For me a 'good' amp is one that is transparent to the signal, taking away as little as possible, adding as little as possible.
Very often this is a very different ranking than preferred or less preferred amps.
Jan
you can always hear when an amp-speaker combo sounds good or bad....
Matti Otala
found by chance : Meeting with Matti Otala (magazine "l' Audiophile")
Who can convert the file format from attached jpg-files by OCR software to transfer the text in a translation resp. language tool (e. g. in "Google) ?
Can you upload the pictures as PDF scanned at 600 dpi.? What is the original language? I can send you the OCRed files for editing and publication.
--G Annaji Sarma.
... yes, but nobody can always say clearly, why.
--G Annaji Sarma.
The files of all articles from "l' Audiophile" are from there:
index
Maybe it is possible to convert from jpg in doc by Abbyy FineReader for the aim of comfortable translation in Google's language tool.
check also this thread
https://www.diyaudio.com/forums/sol...amp-low-resolution-schematic.html#post6749571
if anyone interested to try Matti Otala amplifier, it is easy to do so by buying used Rotel RA-820bx3 / RA-820bx4 / RA-840bx3 / RA-840bx4.
Where 820bx3/4 is without tone controls and 840bx3/4 is with tone controls.
Check it out Rotel circuit attached.
  • 2022-12-27 14_03_01-_hfe_rotel_ra-820bx4_service.pdf and 5 more pages - Personal - Microsoft​ ...png
