Here you can find some photo's of the philips cd880 (with a tda1541a s1 q-selection) and marantz cd880j. Also i see the service manual of the cd880: http://www.marantzphilips.nl/index.asp?strPage=Info&strBrand=Philips&strType=Philipscd880
Van Hal,
Thanks for the reply. I checked with these guys and they only had the duestch version that seems to be so common. I wonder if they made a english version. I just need to align a cdm1MkII laser pickup. I have no way to know how to adjust the motor drive pot which was accidently bumped. If anyone knows the test points and the scope values I should see in playback mode it would be greatly appredciated. From looking at the duetch version it looks as there is a mechanical alignment that must also take place. Any translation on this portion of manual would be appreciated. Also I know a phillips #5 disc is almost impossible to find. Does anyone know a very close substitute that could be used to align this pickup. Donald
Hi Donald.
I do not have the cd880 info, but do have a set for the
Arcam Delta 170, this also has CDM1 MK2. It does have a section regarding Laser alignment, and is in English !
If you wish to have a copy just pm me.
(Other CDM1 MK2 machines may also be an option)
All the best.
All the best.
Did you look up, seven posts ?
http://www.diyaudio.com/forums/showthread.php?postid=1367837#post1367837
Guys...please do send me Philips CD880 and MacIntosh MCD7007 service manual. Thanx.
Email.... shamin6@gmail.com
Help with my Philips CD880
Hi All,
This looks like a great forum for all kinds of audio stuff. So I joined, and hope to contribute where I can. I am looking for a service manual for a Philips CD880 in English? I have found in the past German, Dutch, and Italian, but no English. This Philips cd player gets a read error when a disk is inserted. I had previously changed all the capacitors in the unit as I found two leaking. I can see the laser is emiting light and the arm does move. not sure of the readability and would like to use a scope to look at the signals in order to troubleshoot. Any help would be appreciated.
Hi All,
Van Hal,
CD-CHECK (test disc for CD player evaluation and maintenance)
Service & User manual here:
Philips | Hifi Manuals Free: page 4
Scroll-down or <search> for CD-880
neil
neil
- Digital Source
- Marantz CD85 or Philips CD880 schematics or service manual
