Hi gentlemen,
some decoder on the Bay:
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=110225615884&ssPageName=STRK:MEWAX:IT
Any risk of copy or pin compatible lower performing part?
Matthieu
Matthieu
Well, all Marantz CDx3 were sold on eBay... at ridiculously high prices. If I must put 300€ on a CD63 I'll check what's new on tiwsted pear audio...
Anyone with a lonely SAA7345?
It seems that there is only the GP package as far as I understand the datasheet. I may order the asian one soon if no hope to find a donor...
How much!!! You sure about that? I got 2 63's that needed lasers for less than £10 each and one of them had a remote!
Hi all
I've been looking around for a cheapo mod for the 63, i found coax.
Am i right in thinking you use a mini 75ohm cable, such as http://www.maplin.co.uk/Module.aspx?ModuleNo=269 and use to connect the clock signal for both dac and servo?
If this is so whats the correct method of cabling up and what are the benefits?
Cheers all
Ian
Cheers all
Ian
Hi Ian
The cable looks good. If you decide to use it for signal transfer between mech and HF amp, be sure to connect the braided screen to gnd on only one side.
Regarding clock connections, I never used cable because my two clocks are placed very near the dac and servo.
As for the digital output, these players are so good (after some mods) that I do not see the point in using an external dac. Do you believe shorting the digital output might be benefitial ?
Ricardo
Ricardo
Lacquer can cause issues if it is not fully dry.
Hi Brent
After 1 week, the lacquer should be dry and I got rough times with some boards.
Can I use fingernail lacquer remover (thinner) to remove the lacquer from a built board ?
Ricardo
- Digital Source
- Marantz CD63 & CD67 mods list
