RCruz said:Simon..... I do not know what to say
Ricardo
It's easy what to say.... it's LOL.
Simon is adding comedy value to the thread
Brent
Excellente
They were done like that to split the fat tracks up into smaller ones for the different cap combos etc you can use.
I think it's a work of art, the doublesided layout took lots of checking and re-checking to make sure there would not be a through hole short.
Brent
Brent
How can we be sure the tracks do not short when soldering a cap with thick legs ?rowemeister said:
There are various bits that can and will short, but the tracks are part of the same conductor, so it won't matter.
And yes, it's all funny and everything, but I really, really miss my music!!
Simon
After carefull inspection I see it is perfect.....
rowemeister said:They were also made to withstand Simons legendary pad lifting skills.
Brent
I forced caps in with incompatible terminals, after using snips to make the ends smaller. I've flexed these a few times and probably done other unnecessarily potentially harmful abuse. The boards are like rock!
Simon
Thank you Ray6h5c said:There are some that break everything, and some that fix everything...
BTW, Ricardo, your +/-15V supply will work fine on the discrete PCB. I will simulate with this supply voltage just to be sure, and let you know if small adjustments have to be made.
I have obtained a piccy of Simons decoder chip that reveals the extent of the damage.
Brent
Brent
6h5c said:BTW, Ricardo, your +/-15V supply will work fine on the discrete PCB. I will simulate with this supply voltage just to be sure, and let you know if small adjustments have to be made.
I'm using +-15V SPowers with no problems, works a treat.
rowemeister said:I have obtained a piccy of Simons decoder chip that reveals the extent of the damage.
Ok, fair play, that's fantastic
Simon
- Digital Source
- Marantz CD63 & CD67 mods list
