I have updated the mods list AGAIN!!!!
New TX all over, more SPower and new caps for clocks psu etc.
CD MOD LIST V1555.2
I have also broken the 9Kg barrier LOL
Pics to follow at a later date
Brent
CD MOD LIST V1555.2
Brent
LOL
To get to 10Kg I had thought of chassis modifications. Maybe add some machined wood to the bottom of the chassis. Something that looked like it was meant to be there. To be honest its pretty solid now especially with the bonded plate.
At the end of the day its how it sounds. But the weighty feel certainly helps
Brent
Brent
Ot
I put the Black Gate AC 6.8uF caps in my preamp's output for DC blocking duties.
They're definately coloured to my ears!! Very nice though, instruments are full of warmth, in particular guitars and vocals sound lovely.
Hopefully the slight hazy/fuzzy quality will reduce with "burn-in".
Already I can safely recommend them above cheap film caps (for example, at output of CD63/7 if needed).
Simon
Simon
ezkcdude said:Your links aren't working.
Probably because he copied his post from here:
http://www.diyaudio.com/forums/showthread.php?postid=1310292#post1310292
Hi Everybody,
I have installed a low jitter clock from TentLabs (http://www.tentlabs.com/Components/XO/index.html) powered by a "Sjöström Super Regulator" (http://sjostromaudio.com/joomla/index.php?option=com_content&task=view&id=55&Itemid=27) into my new Marantz CD 67 mkII OSE. The player suddenly began to play real stereo, with incredible detailes to be heard. The improvement is obvious, even guests of mine, who know nothing about electronics, confirmed that it sounds better.
I have made some measurements of the player characteristics before and after installing the new clock, using RightMark Audio Analyzer (http://audio.rightmark.org/index_new.shtml).
The original player:
http://www.sinigersky.com/docs/Marantz CD 67 mkII OSE.htm
The player with a TentLabs XO:
http://www.sinigersky.com/docs/Marantz CD 67 mkII OSE reclocked.htm
For these measurements, a M-AUDIO Audiophile USB sound card has been used. For reference, here is the card only:
http://www.sinigersky.com/docs/Audiophile Out 1_2.htm
When looking at the results one can see a worse frequency response after installing the clock, and also slightly larger distorsion and somehow, more hum is now entering the system (100 Hz etc. spikes everywhere).
My theory about the frequency response is that now there is less jitter content in the high range. Would it be a good idea to modify the analog filter at the DAC output in order to compensate this?
I would be glad to read some comments on the results. Has anybody done similar tests?
I will post some pictures of the modification later.
That's better.
Firstly, I wonder why your tests show the steady state measurements to be worse with the reclocking.
Secondly, a jitter measurement would be more meaningful. It won't be reflected in any of those graphs I don't believe, as it is a timing error, not a response/amplitude problem.
Simon
Simon
SimontY said:That's better.
Simon
I am wondering too.
Maybe the following is happening: the jitter of the clock is a phase noise which causes signal-related "amplitude" noise. When jitter is improved, the noise content (or "power") disappears from the frequency response plot causing more roll off at the high frequencies.
The hum effect should be something else. I tried to move the cables, to reverse the mains power cord plug, but maybe I'm still forgetting something.
I have no explanation about the slight distortion effects.
I agree that the change should not be visible in such an experiment, I made the comparison because I was curious if the sonic improvement would be measurable in this way.
Unfortunately, I have no equipment to measure real jitter performance.
- Digital Source
- Marantz CD63 & CD67 mods list
