rowemeister said:After testing the pcb in its new location I can confirm it no longer cuts out or skips easy. If i tap the mech the laser will jump and then the servo just picks up and carries on as it should do.
None of that spinning the disc backwards malarky now.
Brent
Have you grounded the unused inputs on the spare flipflop?
Not yet. Its still in bits and running.
Brent
Brent
That may be the problem - parasitic triggering
Its run all afternoon with no problems, touching the cable etc is having no baring on it either. Stopping cd with finger and letting go and it just spins backup and carries on.
I will however short the other pins to gnd!
Brent
SimontY said:Just needed a shorter wire from the extra chip did it?
S
It appears so.
I tried the original crystal on long legs and it didnt like it either
Brent
humble me
I started to read this tpic, but already very soon it got to difficult for me. Perhaps time to start a topic for those like me who have not the knowledge others have.
Just another question, isn't there a Dutch "modder" in Limburg. Just to have th epossibility to see one time what has been done. By the way, I did not went shopping yet. The bitum, do you have to glue it on the inside of the top en the sides?
Rein.
Rein.
Re: humble me
Hello.
No. Usually it already has glue.
Andy
Rein said:.......... The bitum, do you have to glue it on the inside of the top en the sides?
Rein.
Hello.
Andy
Re: humble me
Yes stick it to the inside of your lid, sides, bottom chassis and strut bar
Brent
Rein said:I started to read this tpic, but already very soon it got to difficult for me. Perhaps time to start a topic for those like me who have not the knowledge others have.
Rein.
Brent
Re: Re: humble me
Also, you need to be careful to not put it where it shouldn't go and stop the lid going on, or as I did originally, stop the power switch extender from moving freely! It would be safe and effective to just apply one piece - to the U-shaped lid. I found I killed too much resonance and had to scrape some off, which isn't too easy. So there's no benefit in going overboard, some resonance can be pleasing.
Simon
Brent
Simon
rowemeister said:Here is the latest instalment of mods list with servo clock added
Very nicely put together - how about adding some small photos to the pdf? [as you have for the clock divider] It may benefit newcomers to the thread.
Andy
- Digital Source
- Marantz CD63 & CD67 mods list
