No, I asked Victor for one of his oscillators and requested that he measure them, I requested the best one. Some time later he replied that this was the best one he's measured at the -160dB. So that is the one I bought. He didn't think he'd be able to make another that low again as he boards were going to be different and something about the parts, but I can't recall exactly.Isnt that osc spec'ed as 0.1%
What does yours measure? Did you specifically ask that you wanted the lowest -dB figure that he could make? I had to wait and he had to tweak it, with parts etc., What ever he did, to get it down to that level. I think I had to pay a little bit extra for it, it was a while ago.I have victors since I first found him on eBay.... doesn't measure that low.
Where do you get those distortion numbers?
I got the HP339A distortion number from you. I think you posted the pic and said it was greater than -120dB. Then looking at the image you posted it appeared to be between -123dB and -125dB.
I used the lowest (higher distortion) number that seemed reasonable.
When demian was here, he had mentioned what he does to these boards, I think adding a reg to the V+, V- imputs and changing out resistors along with other changes.
But I didn't want to fool with it then as I had the HP339A water boarding issues. Currently everything is apart and sitting in the music room I'm stuck without a bench or equipment at the moment. Kinda like Demian after the move. Except my move is within...maybe that is worse.
Which oscillator is it?
One that's not available anymore unfortunately.
Well a schematic would help.
yes, we can help..... pretty much the mods are as far as reasonable on the HP339A... so it died away. Nothing more could be done.
What help exactly do you need?
-RM
Oh. I would just like to buy one board or a finished unit. They aren't for sale anymore on ebay or here.
Hi Telstar,
What exactly are you looking for?
-Chris
A low distortion oscillator. 1khz and 20khz actually.
How about 10hz to 200Khz with EF95sA low distortion oscillator. 1khz and 20khz actually.
It is from the manual of the Marconi TF1101 I restored.
Hi Refugee1,
What is the distortion for that model? I don't think it's anywhere near what Victor has created.
-Chris
It is 0.5% and there is a fixed filter at 1khz that can be switched in to get 0.1%.
It is certainly up to what I want to do with a sine wave generator and restoring it was fun too.
Frex has PCBs for an LT AN67 oscillator, that does a reasonable job at 10KHz. EOSC10Kv3 - LT AN67 10kHz oscillator : new updated version !
This far my own version of the AN67 oscillator, with switchable frequency &c, doesn't work properly at all - I'm unable to get the loop gain low enough for it to stop hitting rails, so I've gotta do some tweaking - alas I keep finding other toys to play with.
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
