Please check your paypal account. I paid 95USD today into your account audiosine@gmail.com . I also did remarked with diyaudio name as well. I can provide paypal transaction id if needed be.
quan
You made a mistake. My PayPal Id is audiodesine@gmail.com and not audiosine@gmail.com as you have mentioned.
Oops, my oversight. I will have to try to get the fund back from audiosine . I will make the payment into your paypal account now.
Quan
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)+ crystek 950+ tps regs
3) richard_pc - 1 PCB, 1 ES9018K2M + 1 Crystek 950 + TPS(ALL pre-soldered) - PAID
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, 2 TPS all soldered - PAID
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
9) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
10) rredline - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
11) DaveK - 1 or 2 kits
12)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
13)Turbon - 1 PCB, 1 ES9018K2M + 1 oscillator + 2 TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
14)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
15)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
16)vuki - 1 PCB, 1 ES9018K2M, 1 XG1000 oscillator, TPS regs (all pre-soldered) - PAID
17)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered) - PAID
18)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
19)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
20)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
21)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered)
22) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 oscillator (both pre-soldered)
Just sent my payment of $112. Thank you.
5) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, 1 oscillator, 2 TPS all soldered - PAID
Syl,
My payment of $112 also included oscillator. Thanks.
Syl,
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)+ crystek 950+ tps regs- Paid
Thanks Syllable, hopefully paid into the right account this time. Apparently i paid into some transport company in South Africa?. Dud. Hopefully no problem for a refund.
Quan
Quan
Syllable:When the board arrives,besides the digikey BOM do we get a schema as well?
I have a couple of shunregs that I want to use for the 3,3 and the 9v..
I will provide the boards and the parts in 12 days to 14 days but I need all payments to be made asap because I cannot order the parts individually later. You can use shun regs as well its your choice. You will get everything BOM, schema and layout plan.
Sent from my Q700i using Tapatalk
10) rredline - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered) - PAID
12) OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
13) Turbon - 1 PCB, 1 ES9018K2M + 1 oscillator + 2 TPS regs + 1 Crystek 950 (all pre-soldered) - PAID
14) eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
15) Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
16) vuki - 1 PCB, 1 ES9018K2M, 1 XG1000 oscillator, TPS regs (all pre-soldered) - PAID
17) number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered) - PAID
18) badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
19) dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
20) axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
21) linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered)
Paid $72.
(1 PCB $20, 1 ES9018K2M $20 + oscillator $5 + TPS regs $17 + Shipping $10)
Thanks.
Paid $72.
Thanks.
14)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
3) richard_pc - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
5) freeman - 1 PCB, 1 ES9018K2M, 1 Crystek 950, 2 TPS regs (Unsoldered) - PAID
10) rredline - 1 PCB, 1 ES9018K2M + XG1000 oscillator + TPS regs (all pre-soldered) - PAID
16)vuki - 1 PCB, 1 ES9018K2M (pre-soldered) - PAID
I kindly request rest of the members who haven't paid to pay up asap because all parts has to be ordered in one go.
21)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered) - PAID
Hi syllable,
I paid $112 (same as Ryssen) for same configuration including oscillator and pre-soldering. Let me know if this is correct. Thanks. Kind regards.
Hi syllable,
No its not. You paid $17 extra for the TPS reg which has been refunded back. Likewise $17 has been refunded back to Ryssen and Turbon, they have paid extra $17 for the TPS regs.
Kindly read everything clearly before making payment or just pm before making payment.
Two regulators are needed for each board.
TPS regulators x 2 - $17
For two boards you will need four regs
TPS regs x 4 - $34
For three boards you will need six regs
TPS regs x 6 - $51
For four boards you will need eight regs
TPS regs x 8 - $68
Thanks syl, I just copied ryssen.
I recon only one of the oscillator or crystek should be presoldered? Not both
If so i would like to have the crystek presoldered and the oscillator unsoldered. But I might be wrong and maybe both needs to be presoldered?
Only one crystal oscillator can be soldered, crystek or the xg1000. You will only get the crystek presoldered which you had paid for. You will not get the xg1000 crystal oscillator.
Syl, sorry for the confusion. I want same config as Ryssen and turbon which will include the CRYSTEK only plus pre-soldering. Please confirm that I have made correct payment. Thank you.
Ok, thanks for clearing this.
- Group Buys
- Low cost ES9018 DAC board GB
