Loving the AudioSector LM3875 - What next for "better" Sound Quality??
ok I fitted up the caps today :)
sound is a little beefier and fuller, thank you for the help..
6L6. May I ask how you found the sound compared to PASS LABS Amps? Would it be an exponential step up in terms of the sound quality? If so, which amp would you recommend?
6L6
Moderator
Joined 2010
Aleph J is in stock, as is F5. BA-3 front-end is out of stock, BA- complementary output stage with bias board is in stock.
The power supply and chassis (with universal mounting spec) can be common to all the Pass designs. Buy one PSU and Chassis, and then it's easy to swp amplifier stages in and out. Try F5, Aleph J, F4, BA-1,2,3 . It actually is that simple.
I have a set of BA-3 boards that I am not likely to use. (gain stage board, plus pair of single-ended output and bias boards). Please PM if interested.
Steve.
DIY Audio seem to be out of PCBs at the moment. Is there any place I can order them? ideally in UK? [url=http://www.diyaudio.com/store/amplifier-circuit-boards/power-amplifiers.html said:
Power Amplifiers - Circuit Boards[/url]
