LM3886 Schematics + PCB
I like to Parallel Super Gainclone, like as mentioned in Parallel LM3886 Diagram using wire wound 0.5 ohm 1 watt resistor (3) per channel and ground with 0.1uf (ceramic or film capacitor) with 2 ohm 1/w metal resistor.
Mile, Prasi can you guys just confirm whether it will work or not.
Thanks in Advance,
Nandhakumar
Following the datasheet, a single lm3886 can handle 50W cont. avg. output power into a 8Ohm load with supply voltage +-35V --> I = sqrt(P/R) = sqrt(50/8) = 2,5A
So it needs 2,5A continuous current
and 2,5*sqrt(2) = 3,54A peak current
Multiply those values times 5 and you get what 5 of such boards need
C'mon! 2 * 35V * 2.5 A = 175 W. At full output power of 50 watts that would equal to 125 watts of thermal dissipation. Never ever!
Best regards!
Yes, dissipation always is input DC power minus output power.
Btw, 1.25 A of DC consumption, which is half of the value that you've calculated, seem to be more reasonable: 35 V * 2 * 1.25 = 87.5 W, minus 50 W output = 37.5 W dissipation. Remember that each half wave only draws current from one rail, not from both simultaneously.
Best regards!
I did something similar to this.
