lm1875 fizzing away probelm
Was a good idea to use two lm1875 or a big stk chip
  • Total voters
    31
I would have thought an op-amp oscillator is easiest to get working, but if you insist, Rod Eliott has offered a four transistor AF oscillator design
Audio Test Oscillator
which looks very good (as are all his articles). A circuit can be done with only two transistors but the ones I've come across using google briefly appear to have some fundamental flaws. This is what happens when people rely on computer simulations too much and not the good old "solder-and-and-try-it-out" method!!
Is it too difficult to find a 15+15V ( 30 V center tapped)50/60 W transformer ?
You said that you have a 18+18 V one...is it a too high voltage for the application?
When I told you not to mix Pc & audio things , there are some reasons why:
a clean linear supply....is a clean linear supply !!
When you have it done, you know that if something's not going to work, it's not
its fault.
Second, what is written on the decal on the PC psu ? + 12V @ how many amperes max ?
and what about the -12 V line ? is it the same ? I guess no :rolleyes::mad:
and EKKKK! what and where are those ceramic caps ?
its fault.
Its too high voltage for testing and could damage something,but once the amp is out of beta testing i will use it,the psu is 50a 12v and just 0.8a for the minus voltage so that might be a problem
And yes it didicult to find one,i thried so hard for 3 years to find one for a tda7294 and they were very expesive,util recently my mom accidentaly therw out the tda7294
The max transformer voltage I'd recommend is 22-0-22Vac too much more and you'll risk going over the max. You'll need a bridge rectifier rated 5A 200PIV and a couple of off-board electrolytics at least 4700uF and at 35V or more. You should also tidy up the wiring on that board. You should also have a couple of 100uF (gain 35V) on the board wired in close to the IC pins, which, I assume, is also where your ceramic disk ones are. The ceramics are fine for supply rail decoupling so no problems there. You should follow the datasheet I posted earlier as I notice other components missing.
And your power supply is OK for testing but not so to use in anger!
:cool:
:cool:
Thanks to you it now works ,im so happy i will write your name on the pcb so everybody who takes a peek in the casing will see your name and ask why is something written on the pcb,i will say to threm that you helped me the most
