lm1875 fizzing away probelm
Was a good idea to use two lm1875 or a big stk chip
  • Total voters
    31
your hearing is far too sensitive
:p
You should educate yourself on Supreme Audio
:wave2s:
Look around and find some 100W transformer, center tapped
destroy some chips before you get the right way
then you should educate yourself on Supreme Audio
:wave2s:
Maybe your ears don't like chip encapsulated solid state,
maybe you'll like discrete transistors
But if you educate yourself on Supreme Audio
:wave2s:
Maybe youll find that tube amplifiers and old vinyls are the only ones
that bring you satisfaction
Happens ...
:p
:wave2s:
:wave2s:
:wave2s:
Happens ...
Im no audiophile, my tda2003 usb powered sounds fine,but that just distorts so much even at less than 1w
Btw i have some vinils from my mom but i cant use them,i mostly listen to dubstep(dont hate me!),and some oldies
So i got a phone chrarger and i hooked it up to my once powerful tda 8560 and made it into a small amp for my laptop so my tda2003 can be sent to the tv which also needs some good audio,the charger is 9v 800ma and i did 15000uf cap to reduce voltage sag,which is still a big deal,i got some leds hooked up to it to light my room up and the dim with the bass
Adios hiss from tda2003,hello 50hz hum from transformer psu
:D
If you followed what I said in my first reply
:rolleyes::rolleyes::rolleyes:
:eek:
Hum from a *normal* trafo ?
You should rotate and move in space or the trafo or the circuit ( that may caption some noise by some groovy intercapacitance intersections-and resistive-the paths to ground ) to keep sensible parts away from some flux dispersion....force ?:usd::p
:D
:eek:
Normall trafo but too weak far away from electonics.As its an wall wart
Maybe some diodes in the bridge rectifier died from overtemperature from when i salvaged it from the old board,the bridge wasnt new
Not for long ive been using stereo speakers,i really love the stereo efect,but my tda2003 i mono ,th sound system on my old comp has an burned chanell,and my tda 8560 had a sub on one chanel and satelites on the other now its all stereo ,havent heard any stereo sounf for at least 5 years,and the stereo image on my speaakers i grea
Btw have you even seen a cd that has that shiny part very red,when i was 5 i was taking apart a pc(at thaat time i was finding a lot of dumped computers but my mom kept thowing them out)and i didnt know a thing about computers.Took a computer cd drive apart and found a red cd inside,the shiny bottom was red not silve,and it looked awesome,I wold like some now
Anyone knows a good chip that runs at 12v to 5v,is powerfull and single chanell
