Kenwood 9102
See attached.
As always, I'd recommend using the original part number. Mouser has them:
511-STW34NB20
I don't know the color of the LED. If the LED is triangular, I'd think it's likely supposed to be red. If there's only one LED, it's almost certainly supposed to be red. I've never seen a dual color LED that was red and blue (but I haven't looked for any either :).
Edit:
You can probably reinstall the original Q3. It appeared that it had low gain but that was due to insufficient base drive current (due to the open ground). The transistor was conducting but wasn't saturated.
