Keantoken's CFP cap multiplier
Ex-Moderator R.I.P.
Joined 2005
Cool build :)
got power on now
and I guess it works, since I have +15V from a 12V trafo
but no light from the LED :eek:
Ex-Moderator R.I.P.
Joined 2005
got it, thanks...it works
tricky, because those caps must be some kind of small wonders, since they seem to hold voltage almost indefinately
drained the caps with a reisistor....and he LED flashes nicely on power up :cool:
thought I wouldn't need a LED/res supply drain/bleeder, because of the LED in curcuit, but seems I have to mount one
will use for powr on indicator on front panel
BTW, that's a super-stylish trafo there. :)
ripped from a wallmount supply :D
Neat! You turn it into gold. Is that wood? At first I thought it may be something nifty and esoteric but now I realize it's just to hold the trafo in place? For the top part it looks like you drilled holes and cut it out with a band saw? I need to learn this sort of resourcefulness.
Joined 2006
I am starting to cllect parts for the Kmultiplier I am going to use with the JG Paradise.
The Paradise uses shunt psu and draws 150mA on each positive and negative PSU, working at +-18V.
Due to availability I would like to use D45H11 power PNP instead of 2SA1930 for the positive kmultiplier.
For the negative one I have D44H11
Can I use those instead ?
Best regards
Joined 2006
Ok... I will order some :)
Do these need to be heatsinked ?
For the other trannies I have the BC337/327.
I read your text describing the circuit but I am having difficulties following all parts purposes.
What is the purpose of the 820u cap ? Does it get multiplied as in a darlington C multiplier ?
Ex-Moderator R.I.P.
Joined 2005
Is that wood?
hey, I suppose you mean the brown trafo 'chassis' ? ... I think it's Pertinax
its hard pressed paper/glue, and very strong
I just cut with an ordinary metal handsaw, and dress with a file
edges are difficult, and splinter easily...could be better
the rest of the box is scrapped digital 'something', modified a bit, and some plywood
it's really way too much work for what it is, but whatever, its great fun :p
