Hello All,
Hope you don't mind a new member jumping in to the conversation. I also have one of Yeo's Charlize amps assembled about a week now and am also experiencing the turn-on pop. I tried Yeo's mute switch fix but it made no difference. I asked Yeo about the pop and he said some systems exhibit the problem and others don't, he suggested wiring a switch to the speakers. Otherwise Charlize sounds very good, an authoritative bottom end, a warm yet still detailed midrange (how'd Yeo do that?), and a 3-Dimensional quality that sounds live are what stand out for me. Below are a couple pics of my Charlize.
Dave
http://tinyurl.com/buovu
http://tinyurl.com/dy7zn
Dave
She looks very lonely in that big space Gordon! But there is room for Monica as well!
I hope the mute fonction because i will use them with high efficiency speakers who will not enjoy a plop
I know what you mean Dede, I don't even have a crossover between the Charlize and my Goodmans 201's! I may have to get out the Velleman speaker protection modules!
Nuuk said:The circuit that I posted earlier in this thread should work well too!
In this thread ? I'm getting hold as I don't see it
ashok1 said:
This time delay kit looks like a possibility. It appears that the output relay can be configured to turn on after a preset delay and stay on as long as power is applied. So, un-mute the Charlize after say 5 seconds after power is applied.
http://www.electronics123.com/s.nl/sc.8/category.44/it.A/id.386/.f
I'm not sure that it will help. What it need is a soft start that slowly increase the voltage. The mute have no effect on the voltage you send to the amp.... Am I wrong ??
It look like we are a few persons to need a soft start module, why not try to find someone from who we could buy a kit. I wonder if DIYPARADISE could be interested to providing us a kit ??
Anyone interested ?
I can't remember where I post things these days! This is one that I was referring to.
More details here .
I'm not sure why that mute function doesn't work on the Charlize!
is it the mute or the sleep function? which pin on the chip is the switch connected to? if you install a switch for the sleep/awake function you still hear a small pop when waking the amp up. although not as loud as having the amp awake and then turning the power supply on.
DonJuan said:hi guys
glad you guys love charlize.
a business partner is working on a switching power supply with soft start feature but he had some problems with the module. hence the delay.
will definitely let you guys know when it's ready.
donjuan
Great news !
Thanks for listening to your customers !
Seriously, I think placing a switch between speakers and output is a good solution.
Yes, and why not use a rotary switch? A four pole three postion would allow you to have position one as (both power and speakers) off, position 2 as power on/speakers off and then position 3 as both power and speakers on!
That way you could turn on power, wait a couple of seconds and then connect the speakers all with one switch! Of course you would have to short out positions two and three for the power switch!
Hi all,
Please tried switching on the Charlize via a 240 - 280 ohms, 1/2W resistor connected on the positive supply line. bypass the resistor after that for normal listening. This will eliminate the 'start-up pop' issue.
I've tried this method on the Charlize that I'm having (with the air-core as well as with the ferrite core) and now I can only hear a slight 'click' when the 240 ohms resistor is bypass.
Nuuk & vt4c,
thanks for sharing you great idea
I'll try vt4c solution as it's the simplest one to implement. I already have a on/off switch installed for the mute. I will remove the mute wiring and replace it with the bypass wiring.
By the way, next week I'll bring my Woodini (it' the name of my implemantation of Charlize ) to a friend home. He has some big Magna Planar speakers that he power with a Audio Research tubes amp. We want to see if Woodini will be able to deliver some magical music with these beasts. We won’t push Woodini to hard.
Thanks again !
Thanks again !
So long as you don't lock her in a trunk, throw her into the St. Lawrence River and excect her to escape that's OK. Or shall we ask Yeo to modify her a bit more?
no, nO, NO, the only thing I ask to Woodini is to help me to escape from the reality of this world a few hours each week
I escaped reality by coming to DIY hi-fi! Now I'm trying to escape back to reality again!
Not easy for sure
I tried the resistor trick but used two, and a two pole 6-way rotary switch.
Position 1 +off
Position 2 & 3 = 300R resistor
Position 4 & 5 = 180R resistor
Position 6 = straight wire.
This still gives a very small click when the switch is turned to fully on so there's not much point in using the second resistor!
Position 1 +off
Nuuk said:I tried the resistor trick but used two, and a two pole 6-way rotary switch.
Position 1 +off
I have tried one 270 ohm resistor with a bypass switch as proposed by vt4c and it worked very well
The mod was done on my Autocostruire prototype as it was faster to do. Now, I'll open Woodini and replace the mute configuration by the resistor/bypass switch configuration.
It is too late for Woodini (I like the look with two knob anyway). but for my next project, I'll use a rotary switch. It is a little bit more user friendly
Thanks a lot Nuuk and vt4c
Now that you posted these solutions to the POP problem, many of us will use it and live happy with their Charlize
- Class D
- Just playing with my Charlize
