John Curl's Blowtorch preamplifier
I have an 8 channel studio board made of DISCRETE op amps that uses that configuration. Made it for Elliott Mazer in 1980, resided at CCRMA for many years, and was given back to me in gratitude for my effort. It is not the best way to go for a simple power amp. However, I was told that the board was banned by Sony because it was too revealing in listening tests.
OK, what is wrong with an IC front end? Solves lots of problems, but if I were to do it, I just might use Scott Wurcer's IN Amp design, the AD 524, rather than do my own, unless I wanted an all discrete design. Then it would take almost as many quality parts as the power amp itself, and not very practical.
If you are talking about driving a power amp with a differential (i.e. balanced) signal) I'd just go with a diamond buffer driving the power amp feedback leg ground point. Since the diamond buffer is similar in structure to 1 half of th e dual diff input pair (N &P), the bias current s can be made quite similar.
gor general balanced to single ended . . . . jus t take th e signal between th e hot and gnd outputs and ignore the cold output. Penaly is 6dB reduction in output level, but so what.
Well - distortion of the JC-1 input buffer is very low, low order harmonics, inaudible :
Regarding the CMRR - this is not any main issue. To utilize advantage of complementary symmetrical structure, we need balanced drive to cancel distortion. The JFET input buffer enables to use -input in a reasonable way. Do not forget there is a feedback. CTC Blowtorch does not need additional input buffer.
The balanced drive of complementary symmetrical structure is much more important than CMRR with 1 - 2m input cable. If John wanted to use the opamp, he would do so. Anyone can use an opamp.
