PMA said:Everything's fine.
How about additional active filter (so called 'capacitance multiplier') behind the monolithic regulator? BJT, or MOSFET? Why MOSFET, why not BJT?
Reduces noise and improves HF suppression considerably.
I like capacitance multipliers as well. A couple of years ago I used MOSFET capacitance multipliers/pass transistors to provide input stage, driver and screen voltages for a vacuum tube power amp. In some applications like this you WANT the output voltage to track changes in the main power supply, so you don't really want precision regulation, you just want the great filtering and isolation afforded by the capacitance multiplier.
BJTs and MOSFETs each have their advantages in a capacitance multiplier application. One may have to give up a few more volts when using a MOSFET. Never forget to protect the gate from excessive gate-source voltages under turn-on, charge-up, or fault conditions.
Bob
Re: For Scott Wurcer
Excellent, the patent expires in November
PMA said:I tried something similar, there is an improvement compared to
http://www.diyaudio.com/forums/showthread.php?postid=1722023#post1722023
With regard to cap multipliers. I have used them in all quality audio products since 1973, when I put a pair of cap multipliers as a buffer for the phono stage of the Levinson JC-2.
I have used 4 different types of cap multipliers: bipolar transistor, jfet, mosfet, and 'pseudo-zener' regulated.
The first, and most obvious is the bipolar multiplier. It appears to need a large electrolytic cap on its output to behave quietly. That is its problem.
The second is the jfet follower. This design is VERY quiet, but it has fairly high output resistance, limited current capacity, and is VERY sensitive to accidental shorts.
The third is the mosfet follower. It is relatively noisy at low frequencies, but it can drive high currents and is relatively immune from voltage or current overload.
The fourth is replacing the input resistor with a NORTON equivalent Zener by using a low noise current source, usually made by a selected n-channel jfet like the American part # j203, and a selected resistor connected to ground. This resistor must be bypassed with a large value cap, of 22uF or more, in order to work properly in order to bypass the resistor noise and to limit the noise gain of the current source jfet.
This controls both fixed voltage and noise, but it is not very accurate, with voltage, over temperature.
john curl said:PMA, I also think that Scott's cap' improver' is also important, BUT I don't like that particular topology, especially with discrete, as we have a choice about topology, when we build it ourselves. This is not about distortion or feedback, per se.
John
Could you please explain?
Cheers
Stinius
Does it make sense to use capacitance multipliers to power the front end and Vas of a power amplifier.
Is it realistic to investigate the replacement by a capacitance multiplier of the large and expensive electrolytics of the output stage in a class AB amplifier.
What about the large pulses of current?
Will it sound better?
JPV
Bob
Bob
Sorry edit error.
JPV
john curl said:It's tough, without starting a terrible controversy. It has to do with intrinsic open loop stability.
John
Yes, I understand, but this is you thread, **** the rest, you can give us your opinion.
Cheers
Stinius
john curl said:No, it is not my thread, and the moderators remind me of this periodically.
Well I and a lot of others see this as your thread.
If the moderators have a problem with that it’s their problem.
Maybe you should start your own thread the “John Curl interview” thread.
This thread is no longer about the BT, so why not?
Cheers
Stinius
john curl said:The thread is still about BT, if I can do anything about it.
The BT thread will of course still have its own life, but a lot of the posts and a lot more posts could be implemented in the new thread:
The “John Curl Interview” thread is meant to be a discussion thread about all the topics “how to create the perfect sound”
Cheers
Stinius
Cheers
Stinius
There is no perfect sound. There are people here who love planar electrostatics and those that love ultra efficient horns, what could be more different?
Scott
I’m very glad that you see my point.
This is the BT thread.
Cheers
Stinius
- John Curl's Blowtorch preamplifier
