John Curl's Blowtorch preamplifier
The last time I measured, J200 & K1530 have something like 5S at 1.6A bias. So we would just make 0.1R even without source resistor. If we wish to parallel devices to improve max power handling, then a 0.1R source resistor is probably close to minimum, and we start losing transconductance as the bias for each FET reduces.
http://www.diyaudio.com/forums/showthread.php?s=&postid=1507044&highlight=#post1507044
FQA19P20C has slightly higher transconductance at 7S under 1.6A, but there is no true complementary P-FETs to go with. The Toshiba's are really amazing in that respect.
http://www.diyaudio.com/forums/showthread.php?postid=1567443#post1567443
BJTs are of course totally different story.
Patrick
GK
Disabled Account
Joined 2006
Patrick
Just connect multiple output devices in parallel or put a pair into a BJT-MOSFET CFP like PMA did and call it no feedback.
Glen
The hum probably comes from DC on the power line. This is common. Some power transformers are more sensitive to it than others, even from the same stock. AC coupling the power line with a large electrolytic cap is the best solution. It would be best to Google for a small company that provides such a device.
As far as power amplifier design is concerned, I think that high damping factor is overrated. I use a .4 ohm output Z to my 4 ohm WATTS and find nothing wrong with it. I also use a separate subwoofer with only .1 ohm or less output Z drive.
If I were to do this in the real world, I might find a used HCA-3500, run it at 1/2 the rated voltage and change the circuit to single sided folded cascode output. It would be the cheapest and best way to get low Z at reasonable idle current. However, I think that an idle current below 1A is a waste of time and effort, as you will never get the higher order harmonics out of the listening level sound, without at least that much current.
This circuit uses a complementary Darlington output using complementary power fets driving 8 pairs of complementary high speed output devices, per channel.
Re: Mechanical transformer hum on Parasound JC2
Backbones said:
I'm searching for a practical solution over here in the UK for a mechanical hum on this excellent amplifier. Could it be saturation due to the UK's 240v or am I in the wrong place to be asking such questions?
If it's a laminated xfmr, you might try a few good solid strikes with a ball pien hammer (against the laminations). Sometimes this will cure vibrations between the plates.
