AX tech editor
Joined 2002
[snip]I am changing scales to get detail, when I do publication runs, I will try to keep scales the same, but this is still a work in progress.
Ed, if you check the 'Append' box on the AP digital analyzer panel you can get two FFTs in the same window, that would help comparison.
But I guess you know that?
jan didden
The one and only
Joined 2001
Coincidently, I just received another Letter to the Editor on this (related) subject from Marcel van de Gevel. He points out that when you squash the LF gain by for instance a resistor-load on the Vas, the overshoot of the input signal will disappear but only because the final error value increases.
I don't think he was stating that as cause and effect. Both are the result
of lower open loop gain.
:cool:
Iow, instead of an overshoot of, say, 1V and a final value of, say 0,2V, you now get an overshoot of 1V and a final value of 1V. Of course that doesn't look like overshoot anymore but nevertheless is a giant step backwards wrt linearity of the amp.
See http://www.linearaudio.net/userfiles/file/letters/Volume_1_LTE_MvdG.pdf
jan didden
Nice to read Marcel van de Gevel. For same conclusions, see Bob Cordell's book, pages 500 to 505 and fig. 24.1
All this chatter over tired old papers. The world has moved on, there are many examples of amplifiers on high speed processes with simple signal paths that obviate all these old bogey men. GBW and slew rate to spare, why are you still talking about Baxandall's feedback around very low gain paper?
Thorsten, I don't need to hide from anything on Jan's site it's just that taking on these worshiped artifacts draws the pichfork wielding villagers.
Hi Scott, so you propose to put Si-Ge OPA1611/41 or something similar, but where is a fun then?
And more importantly, how does it sound?
Or are we to accept Bonsai's premise that since it performs at the measurement limits of today's THD measuring equipment that it must perforce also sound at (or beyond!) the limits of our hearing abilities?
John, why didn't you use these in the JC-3 phono stage?
That's just one example of an amplifier that makes all those papers old news.
I know that is a competitor's product. But obviously ADI has similar products. The TI datasheet gives very little useful information (except for the unusual fact that the output stage is a complementary common-emitter affair.
Just as many are interested to find out the circuit details of the Blowtorch, it might be interesting to find out the circuit details of these new op-amps that make everything else "old news". Is there anything you can share with us? Or is it like Bybees' classified quantum filters?
www.hifisonix.com
Joined 2003
I absolutely did NOT say that. And if my statement could interpreted in that way, then I was not clear enough.
What I have suggested is a bit less dogmatism, a bit more perspective and a great deal more latitude. I don't doubt your discrete designs sound wonderful (and I mean that). Now what I'd like to see from your side is an acceptance or an acknowledgement that integrated opamp solutions can also deliver a pretty fine listening experience. We are talking very small shades of difference here - no need bring out the pitchforks every time a contributor suggests an op amp might actually deliver a great result- measured or sonic.
Hi Scott
I don't know. Looking at the datasheets I'm very unimpressed.
The chip seems rather sensitive to common mode effects, slew rate and gain bandwidth is pedestrian. And no matter how hard I try, based on the datasheet I cannot forsee any Audio Application for this IC, where it would actually provide decent performance.
I think I take your AD797 or if I can tolerate 3dB more LF noise I'll take the OPA1632 at the very least.
BTW, has AD got a credible moder equivalent to the AD811?
I really liked the AD811 as MC Cartridge input AMp.
Ciao T
Hi Jan,
This is only partially correct. If I use up the excess loop gain in local degeneration and if needed local loop feedback my error value will be as before (unless it derives solely from the final stage), however the overshoot will be reduced or gone.
In other words, if we lower loop gain at low frequencies in a manner that makes good use of the reduction to linearise the circuit, we have only made improvements, no dis-improvements will be observed.
Sorry, I really do not feel like writing an LTE about such obvious obvious stuff, so don't ask.
Ciao T
Tsk tsk, what length people will go to to defend an orthodxy neither worthy of nor in any possibility of defending
I found schematics, technical details, and measurements on TI's website.
Wow. So you found details about this "pre-output driver" black box? Care to share a link?
Btw, OPA1611 has 4,5mA max quiescent current, 1641 half of that. How much flows through the output stage? Common emitter with low bias current into low impedances is not what i would call as linear as possible befor closing the loop. And loop gain depends on output impedance.
I like transimpedance outputs (as the blowtorch is btw) but they must run class a. If i had to use this thing, forcing the output into class A with a resistor or ccs towards a rail would be mandatory.
AX tech editor
Joined 2002
:cool:
Not sure I get your drift Nelson. He was specifically commenting on the practise of loading the Vas to obtain a wider OL bandwidth and showed that that actually makes things worse. Because it lowers loop gain (and thus closed loop linearity) below Fc while doing nothing for the high-freq linearity. So yes it's a result of lower loop gain.
@Thorsten: Yes, there must be myriad ways to skin the linearity cat. But as mentioned above, Marcel's comment was to the Vas loading as a panacea.
jan didden
AX tech editor
Joined 2002
PS Just signed up for Facebook.
Recommended - gives you unprecedented peace of mind and insight :D
jan didden
