Sure, but that's another design goal, related to aliasing, not settling time. Or have I missed some relationship between the two?
I could understand if this was a non-linear error, but its entirely linear - just results in a level change. Stereo pots (just to choose a random example) introduce far greater level errors - they'd need to be jolly good to maintain their tracking error below -43dB.
I'm still confused. How are linear filters and inverse exponents different? To me an inverse exponentially settling filter is a linear filter. If you think its non-linear, please explain how this comes about.
Sorry for the delay, a bit busy.
First lets make sure we are using the same words to mean the same thing.
An analog system is continuous time and level. A digital system is discrete time and level. A sampled (or discrete time) system is discrete time but continuous level.
A linear system follows x=c*y. No system is ever perfectly linear.
A non linear system has some added component x=c*y + d*y*y. ( c and d are any constants)
When we design a filter we can use a mathematically derived filter. There are many of these and most have a name. So if you want a minimum phase, sharp cutoff, or flat pass-band you can in theory select a filter design that will mostly give it to you.
Of course what is unanswered is which filter sounds best in a given application.
In designing or evaluating filters the two classic methods are Bode and Root-Locus. Bode is usually used for filters and Root-locus for control systems.
So when I mention that the settling of any RC filter is based on an inverse exponent I consider that to be classic engineering math. (Classic does not mean simple!)
You can look at the output of a D/A converter either as the step response or as the frequency response. Different view of the same thing in theory!
When you look at the step response of of a signal it will settle say 44 db in one sample time period. If the step is single bit then the error is small and is down by 44 db from the step size. If the step is full scale output the error is the same 44 db down but in terms of absolute output voltage -44 is a big error.
If the filter did not have the response of an inverse exponent but had a constant voltage error then it would be say 40 db down from a single bit and with a 16 bit PCM (Pulse Code Modulation) converter it would be down 136 db from a full scale step.
So the issue is what kind of filter has a fixed error rather that an inverse exponent or even constant percentage error.
A second big issue is adding some signal to the input of an A/D converter to improve the apparent sound quality.
As a given A/D converter is in theory accurate to 1/2 bit then any input should be digitized to with 1/2 bit. But at some levels it may, due to random variation, be + 1/2 bit at other levels it may be -1/2 bit or even somewhere in between. An added signal (dither or similar) bounces this error around in a method that makes this sound better to us.
However in an oversampled A/D converter with a skillfully applied signal that deliberately adds or subtracts a 1/2 bit over the full oversampling cycle, you may be able to improve the resolution of the conversion. (If you are oversampling 16 times with the proper added signal you probably can get 3 more bits of resolution, other caveats apply!)
Now if we want to produce a D/A converter that makes use of this we can use an oversampled PCM converter and some math on the digital signal to produce an output that when passed through a known filter type gives us our desired response.
That next raises the issue of real filters versus the mathematical models of them. All of the analog filters we look at use capacitors. These have "soakage" inherent in the way they are made. This adds another non-linear factor to the filter's unit impulse response.
The best solution is to use as few capacitors as possible and of the best types. These are expensive and more so the larger the values. So for now a good approach is to over-sample, use a very high rate and a small filter capacitor.
This is similar to the single bit ratio-metric approach. The limit to ratio-metric is noise distortion. So by carefull selection of the number of bits in a PCM converter and the oversampling you can design a better D/A converter.
As the technology improves the number of bits and the sampling rate also gets better.
ES
Suppose I had JJ stop by my place and I set up a system with a switch in it to reverse the line level interconnect direction. If he would state that he could hear a difference and was satisfied with the demonstration being accurate, would that count as much as a more formal test? What effect would that have on your opinions?
In some senses, yes, since I absolutely trust your ability to set up and verify the test without obvious errors in an electrical sense and to deliberately not choose a nonsymmetrical . No, in that neither you nor he have escaped having human brains and need to verify your impressions with controlled subjective tests (i.e., blind) in order for them to have any credibility. But JJ wouldn't need to be told that, and I'm certain that the first thing he'd do is try to verify that the effect is actually auditory.
My assumption here is that you're talking about an interconnect that's built symmetrically, with a result that's extraordinary. If it's asymmetric (e.g., shield grounded at one end), the result would be totally unremarkable.
Ah a reasonable and rational answer!
So why is it that you participate in these threads? :)
ES
MID 50's please!
Sy,
ES
j.j. (no Caps) writes in a pro-audio forum, about how difficult it is to setup an ABX test. So many unintended variables to be accounted for. As "X" can be easily identified even before getting to the heart of the test.
Well, I don't mind given things my own listen. Weekend progress on Borbely headphone amp (left), choke power supply (right).
Laying out enclosures --> protocase.
Jakob,
I do agree with you; critical listening under DB conditions most probably needs some special training or focus or introspection, whatever you want to call it. Sighted listening runs on a kind of autopilot, it's what you've been doing all your life, it's a natural process for your brain to incorporate what you hear, what you feel, what you know about the DUTs, what you know about what they cost, how your peers rate them etc into a final opinion. Now all of a sudden your brain has to get used to form this opinion with just ONE sense instead of 6 or more. Definitely needs preparation & building up experience!
jd
Absolutely. And as we are humans, the same mechanisms could help to grasp the ´real thing´ or could led to a totally false perception.
And quite the same mechanisms are still at work under blind test conditions.
In a blind test we block the "peeking" part but add a "destabilization" part as we are (normally) not used to do decisions only by _one_ sense.
Our conscious perception is the result of the reaction of our sensory system to a stimulus and the following quite complex filtering of this reaction.
Reg. se´s post; you simply can´t have it both ways
first- you have to do controlled blind tests (despite of all of your listening experience)
and
second- no we don´t need training and controls in our tests (because of all of your listening experience)
AX tech editor
Joined 2002
Yes. Another interesting thing I recently learned:
Did you know that of all the hearing hair cells that are groupd in a certain frequency area in your ears, only about 1/4 functions as inputs to your brain, and that the other 3/4 are actually DRIVEN from your brain to enhance the movements of the 1/4 input hair cells?
It's a positive feedback process that allows the brain to suppress freq bands it just isn't interested in at this particular moment, or to enhance the sensitivity in a particular freq band it IS interested in. So hearing a tiger roar can let the brain adjust your hearing sense to focus on the roar while you become totally unaware (literally momentary deaf) to the other sounds around you that are not so important right now.
It's mostly automatic, but you can use it to conciously 'listen' to a certain sound, for instance. I wonder how this mechanism impacts sighted and DB listening?
Anyway, knowing this, the phrase 'I hear what I hear' takes on a whole new meaning to me.
jd
Janneman's post is exceptionally interesting as it explains what many of us have experienced in certain circumstances. Perhaps it explains why it is that becoming used to one's wife's voice can result in temporary deafness - especially when she wants money for something considered such as yet another pair of shoes!!
This whole matter of DB testing was as most of us know, covered widely if not deeply in the infamous marathon thread on cables - which had to be shut down. Can anyone with wide experience in fact describe the benefits of true DB testing?
That was also done several times in the cable thread, unfortunately to little effect on the pre-Enlightenment thought process rampant in corners of the tiny, niche high end audio community.
It all sums up to this: it will distinguish what you can actually hear from what you imagine you can hear. That frees you to concentrate efforts on variables that actually make a sonic difference.
My experience- a few dozen (amateur) double blind audio tests, a few thousand (professional) double blind haptics tests, and a few thousand (professional) double blind organoleptic tests. Outside of sensory research, a few hundred (professional) double blind biochemical tests. Reasonably "wide experience."
@ janneman,
isn´t that the quite new research result about the possible working mechanism for outer hair cells helping the inner hair cells ?
@ brianco,
a proper test (which means a lot more than only being double blind) can give with a quantifiable probability the result that a certain effect is really audible. :)
And of course the phrase "is audible" may have a lot of different meanings. It could be "audible to at least one listener (on earth)" or "audible to the average person (means of all persons living on earth)" or "audible to experienced listeners (depending on the definition of experienced)" and so on.
In a _proper_ test it is somewhere descripted what the aim of the investigation was.
I have talked about that many times and i will do it here again. A hypothetical totally transparent system may not sound totally satisfying because we are listening to a recording and not reality. So it could be that a technically non perfect amplifier sounds better most of the time then a totally transparent ( or call it blameless ) one. When i develop preamps for example i use a straight wire bypass and compare input to output.
Still in the final stage of development i do some tuning so that the preamp gives a subjectively satisfying result in a real world condition.
Yes. JJ is trying to determine general audibility thresholds for certain phenomena. I am testing a specific claim by a specific individual in a specific context. Very different things.
I am terribly sorry, but jj for very good reasons did not restrict his assertion for a certain class of experiments. The requirements for good/proper tests are simply the same for all hypothesis tested.
I'm terribly sorry, but until you can show me that a bright and accomplished fellow like jj actually said such a ridiculous thing, I do not believe you.
Now that is something I agree with.
<snip>
The requirements for a test are that it has to be objective, reliable and valid.
These requirements are totally independent of any hypothesis tested. Do you really think jj would find these requirements ridiculous?
