yes, I agree that correlation does not explain cause. it does point a finger for deeper understanding on what might be the cause.
Lets not include audio for the moment---- DBT are used in say pharma research and bio research with as many test subjects as can be reasonably done within time and budget -- If all looks promising, it goes thru FDA et al and gets on the street and doctors list of go-to solutions/cures.
It does not matter how large the priliminary test numbers are for the DBT.... often, later the results are found to continue to be valid or often they are not... When millions of people over years are evaluated, often the drug has to be discontinued. Even though it originally passed the DBT. [Not discussing the weird off the wall exceptions but the fact that it doesnt work as they thought it did.]
Now lets not take this short email apart... but note that DBLT are Always too limited in numbers compared to the total population doing actual listening for over a period of decades. So, I would lean to At-Least having an open mind to contrary views or experiences via a DBLT.
But again we're left not really advancing our meaningful knowledge, just trying to come up with correlations to help reinforce peoples' religious beliefs.
se
Just to nail my colours a bit more clearly to the mast:
1. I've found that a sufficiently capable system delivers a quantum jump in the subjective quality of playback.
2. This quality is typically not achieved by focusing on the parameters that are normally dealt with, or optimised. Further, even if solely concentrating on optimising aspects that are responsible for this quality it can be difficult to achieve, and is highly susceptible to influences of the overall electrical environment - i.e., it is not a system state which is robust, at least with current knowledge.
3. This makes it exceedingly difficult, at the moment, to present a mechanism which can be subject to strenuous DB and similar testing.
4. Anecdotal accounts suggest that quite a number of people can experience this 'effect'; and, conversely, relatively few people achieve a system this capable.
5. This all suggests to me, in spite of contrary viewpoints, that it's worth persisting with attempting to understand this behaviour, and to replicate it on demand.
The DBT tests done by the best minds in thier fields with the best methods known to mankind does not mean the test wont fail when larger numbers over time are used. This has been born out many times and should be common knowledge by now.
Thx-RNMarsh
Note: I am not defending any particular test or product and there surely are some duds out there. Just kept to the narrow issue of DBT and meta-data and results that change after a carefully controlled DBT said it was OK. The big picture.
Note that in these fields of hard science, DBT [and other's] are used to determine if the drug can get into the market by doing something useful/desireable. However, the drugs efficacy and whether it is found later to do nothing and is removed, is not determined thru more DBT. The 'truth' is learned thru analyzing the raw data from thousands and millions and billions of doses and outcomes.
European medicine uses both old and new. What works. The old has proven its efficacy for centuries and thus needs no Scientific Proof methodology and is accepted and practiced together as both correct ways to get to the truth of the matter [cure].
So I say it again, this DBLT is a nice first step. But, it is not the final word... and does not mean the results will be found to endure the test of time and collective knowledge.
Thx-RNMarsh
I don't think that is entirely correct. There are in fact drugs on the market which are accepted as efficacious for one reason or another. What the drug companies have quietly found is that they don't actually outperform placebo. There are treatments that have been effective for centuries because they are placebo and placebo works. See the link posted by JCX.Note that in these fields of hard science, DBT [and other's] are used to determine if the drug can get into the market by doing something useful/desireable. However, the drugs efficacy and whether it is found later to do nothing and is removed, is not determined thru more DBT. The 'truth' is learned thru analyzing the raw data from thousands and millions and billions of doses and outcomes.
Thx-RNMarsh
You've missed it.
Look deeper and broader.
Unless you're claiming that humans are immune from bias, explain to me how you can draw anything meaningful from correlations involving humans prone to bias.
se
se
Right. Sure. What ever. -RNM
Try Ferrites For Yourselves....
Several tracks later it was remarked that something did not sound 'right' about the stereo, and this from two guys who know nothing about electronics, much less audiophile level gear, but they do know the sound of that particular stereo.
I kept stumm, and made no comments or suggestions...I was being perfectly careful not to, in order to keep this as a blind experiment.
During this whole period, all talk was about cars and none about electronics, audio or sonics.
Several cd's later I revealed that the change was caused by fitting the ferrite, and the then sighted testing further confirmed the blind result that they did not like the change imparted by the ferrite.
Dan.
Ok, so I walked back into the garage, determined that we needed a particular bent long nose pliers, went over to the bench and whilst finding the tool, surreptitiously clipped the ferrite onto the stereo power cable, skipped back two cd tracks and immediately returned to the car.I can understand 'cueing', but I'd love to hear a full technical dissertation about how Dan, purely by body language, etc, managed to convey the message that the listeners were meant to hear a sound that was worse, rather than better, than previously ...
Dan.
+1.
Dan.
I find this interesting that ferrites can alter and ruin audio frequencies so badly.
I do remember in a discussion on them many years ago, someone mentioned an audio publication revue where when the revuers saw the ferrites in the amp they slated its sound even though it measured very well!
I would presume that the effect of the ferrite can be measured, andf some screen shots of the altered waveform or FFTs of the amended spectral content are available somewhere?
BTW If you are interested in the difference between correlation and causality, a nice, somewhat tongue-in-cheek article can be found here: Theory of the Stork: New Evidence - Perfect Health Diet | Perfect Health Diet
jan
jan
Thank you for the link.
From a technical point of view, this is in support of SY’s ballbreaking insistence in rigorousness when planning and testing trials and Richard’s additional need for metatesting.
From a medical point of view, “the body's innate ability to heal itself” is the main issue.
From a psychological/sociological point of view, the article doesn’t lead me to any different thoughts on human nature than the article on “Magic” I was reading a week ago in the 1991 edition of Encyclopedia Britannica.
Steve, yes. We are all prone to -pure Class A level- bias.
George
Fundamental error No2 : the expert assuming to have understanding and insight in the core issues of the problem at hand.
But what do I know ? I'm just a gigolo, everywhere I go, people know the part I'm playing.
If 50 million people believe in something that is wrong, it is still wrong
quote
(The) Rules out a drama queen.
Lawyer !
(+ amateur theatre prima donna, possible hormonal treatment, antidepressant therapy )
Great explanation.
se
That is all you are going to get from me on this forum. Do your own home work. The scientist doing research rely on others with expertise to collaborate with on designing the tests and trials to see what is true to the best of thier abilitites. Metadata studies on larger numbers than any of us would ever do for audio/listening tests is an important part of determining the truth after all is said and done.
OK. What's next?
Thx-RNMarsh
Fundamental error with the analogies: an experiment to answer question A and an experiment to answer question B are likely to be structured differently.
Which analogies? (I agree with the structured difference)
George
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
