I've done a lot of modifying of gear with the intention of attenuating the amount of high frequency, non-audio signals, noise, moving around inside the enclosure. High frequency signals are notorious for being able to couple to just about anything, one way or the other, and I have always heard benefit by reducing this element. PSRR always falls off in circuits with increasing frequency, so you're certainly doing the component a favour by reducing that type of noise.Are you sure that is the the Only thing affected which had audible consequences? Or the explanation of the change in character?
How does that correlate with any audible sound change description made?
Typically, for me, better snubbing of high frequency glitches reduces the "dirtiness" of the sound, improves the sweetness and subjective extension of the treble, enhances apparent dynamics.
Frank
Frank
This is consistant with a zillion people's comments over decades on film capacitors' being used for pwr supply bypass. Similar affect occures with a wide band, low Zo regulated pwr supply. -RNM
What you had done was to improve the filtering out of very high frequency noise; all those electro's would have had high ESL, and so their effectiveness as capacitors at high frequencies was severely curtailed. Straightforward bypassing of the power supplies was achieved by the 4 uF unit, and the amount of intermodulating of high frequency grunge with the audio signal was reduced ...
The fact is, amplitude intermodulation was not changed actually.
I thought you said the heights of sidebands on IMD test had varied. So the intermodulation behaviour had altered; adding the 4uF capacitor changed the supply's impedance characteristics, as RNM stated, sufficient for audible effects ...The fact is, amplitude intermodulation was not changed actually.
Frank
Yes. Upper and lower sidebands became of slightly different heights that indicated phase intermodulation. I could not understand why, but found a working hypothesis that it is because of semiconductor properties of oxide film dielectric that play with inductance and capacitance modulating reactance with current and voltage.
It was a tube amp. Primary impedance of output transformers was 10K. Impedance of 4 microfarad capacitor on 20 kHz is about 2 Ohms. 20 Ohms on 2 KHz, 200 Ohms on 200 Hz, and so on. It shunted 4 caps in series, 2,000 microfarad each. 500 microfarads total.
If to remember about experiments with spark gaps, ten microsecond delay is perceived as audible shift of sound source image. I can't think about another explanation.
You have 4 caps in series, order of 20-30nH ESL each, so probably over 100nH total. The paralleled cap will be of the order of a couple of nH, definitely changes impedance characteristics there.
Plus, screw terminals on the electro's? These are as dodgy as hell, my first decent, bought amp used these and the quality of the connections here caused all sorts of audible problems. I ended up ripping them out and replacing with leaded caps throughout.
Frank
Frank
Yes, but you should not add up each curve because they are not separate lumps of power but the same lump of power decaying with time. It would be like taking temperature measurements in my room every minute and then adding them up to 'prove' that it is hot enough in here to melt steel! I'm sure you can do better than that.RNMarsh said:If you add up each curve, the total power curve is VERY peaked.
Those graphs tell us very little without more information about exactly what was done. Lets assume someone applied a step change in voltage. The exponential decay of the bipolar suggests some series resistance. The slight ringing on the other one suggests some inductance. No great surprises? Stop Press: I see you have just confirmed this in a later post. Why do people always talk about 'time smearing' when they see a first order rolloff in the time domain? if you put a perfect resistor in series with a perfect capacitor you would get graphs like that.RNMarsh said:The peak current thru two caps of same voltage applied and same value.
Geeez did you guys miss the point? I am talking about test equipment measurements which correlate better than freq response or thd. It seems to have gone right over the heads of the readers here.
We are often told -- that because the thd or phase or freq response is super good, listeners are nuts to hear what they say they hear. It started with caps but I moved on to other areas.... …
Indeed, some people here seem to miss your point.
Your point is valid, of course. Possibly it's difficult for some people to break through their long held thinking patterns.
Being an audiophile and retired electronics technician, I found out that published measurements of audio gear, as long as they are not grossly off, are absolutely meaningless to the sound quality as perceived by me.
I'd love to hear from you if you had come up with measurement that are more correlated to the realism of reproduced music than frequency response, THD and IMD.
There seems to be very little effort here to separate solid engineering practice from extraordinary claims. I find discussions like Rod Elliot's far more objective. He even removes pages as he learns better. I can't claim it was me, but after I posted somewhere that he had the distortion characteristics of microphone capsules in constant charge vs constant voltage mode reversed he fixed it.
Capacitor Characteristics
I still have not seen an explanation of the claim of a device that distorts a complex waveform and not a sine wave of the same peak amplitude. "Sounds like" and measurable are different.
I have just had a second look at the plots shown by RNMarsh in post 24421. It is probably an 8th-order filter (my rough estimate) and not even maximally-flat (although nearly). If you read a book on filter synthesis you will find that a high order filter can be made by cascading appropriate lower order filters. To get near maximally flat some of these will have highish Q and some lowish Q. The highish Q ones will ring. This ringing may be be heard as ringing or smearing, even though there might be little or no actual peak in the overall response because of the flattening effect from the lowish Q ones (which won't ring).
I didn't spot that this was a high order filter at first. The poster did not draw attention to this. Apart from anti-aliasing etc., how many people include high order filters in their audio systems? An ordinary first order rolloff won't do this. Exactly what point was being made?
I would love to see someone recreate the signal chain for some of the 1959-1962 recordings of, say, the Chicago Symphony and then subject them to the new metric just to prove how "bad" all those RCA Reiner recordings are supposed to sound.
If to remember about experiments with spark gaps, ten microsecond delay is perceived as audible shift of sound source image. I can't think about another explanation.[/QUOTE
Why did you had the 500uF there?
There seems to be very little effort here to separate solid engineering practice from extraordinary claims. …
All the above is fine and valid, only, it doesn't address what RNM wrote here repeatedly:
(Post #3091122)
(Post #3091476)… When something doesnt sound right, we tend to dig out the thd/im/frequency response tests. if all is good/normal then we say the people hearing something a particular sound are crazy or worse. Instead we should find a test that does correlate. …
…This is another example (besides cap DA) of how linear distortion SOUNDS non-linear.
(Post #3091519)… I am talking about test equipment measurements which correlate better than freq response or thd. It seems to have gone right over the heads of the readers here.
We are often told -- that because the thd or phase or freq response is super good, listeners are nuts to hear what they say they hear. It started with caps but I moved on to other areas.... you guys are still on caps and distortion? …
… My point is simply that when listeners say they hear something and describe it, consistantly .... there are measurements that seem to correlate to that very audible description.
Why are you asking?
Also, the question is, was it passive, or active filter. Active components are non-linear by definition.
http://downloads.hindawi.com/journals/apec/1988/070678.pdf
Yes, talk about music and good recordings, after all Hi - Fi starts there.
A couple points -- it isnt an 8 pole... much less. --- the perception of ANY filter with a cutoff better than 6dB/octave will exhibit a longer decay time near the cutoff (amoungst other artifacts). The total energy is another aspect of what is heard. That affect on hearing is what many people describe and not ringing which is a different description.
If memory serves me -- ringing would show up as a ripple in the decay time data.
Thx,
Richard
Would be interesting to see your measurements repeated without it.
People used to successfully filter PS like that with only a 4 - 8uF paper oil capacitor.
It was not about filtering of 100 Hz pulsations by people. It was about dynamic resistance of power supply to power 2x100W class AB amplifier that had to show high-end properties of sound reproduction. Class AB means current consumption highly modulated by envelope that causes dynamic distortions.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
