Jam's Simple Bridged Killer Amp! (split)
How about converting it into a balanced bridged amp which could solve the feedback issue.
It could turn out to be the ideal amp.....................;) ...............any comments?
Jam
darkfeniz,
You do raise a good point. The circuit would work best with balanced drive but you would have doubled the slew rate and almost four times the power (assuming an ideal power supply) and feedback should correct for some of the distortion.
I have a gut feeling this would turn out to be a great amp...........I have been considering this topology for some time......I need to get around to building it.............:yes:
Jam
Ok...Ok
How about this................remove all the global feedback apply more degeneration and set the gain by R1.
Should make all the feedback hating diyer's happy.........a non global feedback bridged amp.......:D .............comments?
Jam
