Is there a Tube Mc Riaa?
The last 50 years or so people have searched for MC tube preamp but the alternitives like transformer, fet, opamp, discreet as first stage were always a better choice. It can be done but always with great compremises.
Volume control you do by adding a resistor to pin 39 and ground.
MM tube amps with srpp first and second stages i have build before. For all tubes designs i like the phonodude.
I like the sound of srpp stages with ecc99 or 6n6p. I use them as outputbuffer for my cd player and dac. I also build preamps with 6n16 with srpp and cathode follower.
But for phono preamp you need a lot of gain, good psrr and driving all possible impedances at the output. Then the mu follower is a good choice.
Soundwise i did not hear a lot of differense between two setups with the same tubes.
Harmonics are a bit different between srpp and mu follower but if distorsion stays below 0,2% i can not here a difference.
