installing a temp indicator on the voice coil
Sure, that's one way. Even simpler if say you are using an analog meter is to amplify it while removing extraneous DC and place paper over the back face and mark lines with a pen. done!
Do use the PC to align it 😉
There are also volt meter chips that drive displays. You still have to condition the input to set things in the proper scale. The "removing DC" part is as simple as using an opamp with the non-inverting input offset from zero.
You can do a lot with a linear expression in the analog domain. And even non-linear expressions, too, but that's a whole different topic.
davygrvy
I may need to build this right into my ppp KT88 sub amp when I get around to building it. I have been working on a digital VU gauge, that and a coil temp on the front would look amazing. Should have no DC off set using an opt but how will this change the sound/output of the amp? Running a DC bias on the out of a OPT just sounds like a bad idea :warped:
and off topic but when you end a sentence with a smiley where do you put the punctuation mark?
