Don`t know the volume played here. But the actual voltage into the speaker is quite easy to measure with a volt meter. I often get suprised how low it is.My Purifi have 88.7dB and it's just to little for MA12070 I just heard when I bought the new TPA3255.
So maybe 90dB could be a good start.
An extra check with SPL meter often confirm the results.
70 watts into a 6 inch speaker is quite a lot stress for such a small voicecoil.
guesstimated the diameter from the dB number
Don't think so.70 watts into a 6 inch speaker is quite a lot stress for such a small voicecoil.
https://ptt.purifi-audio.com/shop/p...,5210,5211,5212,5213,5214,5215,5216,5217,7591
Sorry for that stupid long link numbers...
Linear excursion, Xlin | ±9.8mm |
Maximum mechanical excursion, Xmax | ±14.5mm |
Long term maximum power | 250W |
Don't think so.
Xmax | ±14.5mm |
Yes you can very easy EQ the low bass without bottom out.impressive for a 6.5 inch! Better than Tang Bang HP...
Just love this element!
Yes it couldn't take care of it high volume but the new 3e TPA3255 is nice.Indeed the MA12070 should really be limited to exploit this type of hp
But still love MA12070 at HF as I have!
Think maybe you held back some important information like 15 mm xmax.My Purifi have 88.7dB and it's just to little for MA12070 I just heard when I bought the new TPA3255.
Have you already measured your board? Already assembled the analog version?My ears are my main test instrument, so you can't rely on my results. But I will get the analog one tested once I'm done with my new DAC.
There are no recommendation for coil induction, only says that the minimal induction must be 0.5 uH. And measuring test goes on 22uH inductorsLooks like it has implemented a LC filter, but the 10uH inductors are more than what's recommended by Infineon.
As far as I can see, Purifi use different terminology - and maybe you've fallen for it.Think maybe you held back some important information like 15 mm xmax.
From https://ptt.purifi-audio.com/shop/ptt6-5x04-nfa-01-ptt6-5x04-nfa-01-283
Maximum mechanical excursion, Xmax | ±14.5mm | ||
I would expect Xmax to mean what they call Xlin, and Xmech to be what they call Xmax.
Having said that, +-9.8mm linear is not to be sneezed at.
Can you explain a bit more clear please (rephrase) or even beter a picture how you connect unbalanced inputs the best way? Just to be sure I don't make any mistake. I want to do 2 unbalanced in and 4 out2 and 9 millVolt or 0.002 and 0.009 Volt can be ignored as it can be called zero offset. Probably will be even less with better filtering. I wouldn't even worry till about 20 mV just for the sake of desired "perfection" as even 50 mV won't harm a loudspeaker.
Speak0A and Speak1A should both be + AFAIK. I have the 1.3 so judgement from your 1.5 picture.
Balanced inputs are nice but less so without balanced volume control. Only if you are truly faithful you can connect a power amplifier directly to a device with software volume control. It can go well for some time, many did it ...and burned woofers. I am curious how most balanced people (I see what I did here) do this as 4 channel potentiometers are not the best. Probably relay based stepped attenuators are about the best one can build. Gustard does this in some DACs.
Unbalanced to balanced active conversion with unbalanced volume control in front of it is way easier and cheaper to realize. Better than the single cap to GND ChiFi way of doing it.
If the amp is set to 25dB gain, then 2Vpp in makes 35vpp output for BTL configuration. To be able to do that will require the amp’s PSU to provide 35v/2+4v for dropout on the MOSFET. So is your PSU at least 22v?
Another thing to consider is what it the speaker impedance and how many amps does the PSU provide. You could also be current clipping if driving a difficult low impedance load.
If the PSU is either voltage or current limiting the amp, you will get clipping and distortion when driving near max output.
If you have 8 ohm speakers with an output lower than 90db, there will be no miracle...24 volt power supply recommended.Hello all ! My CD player with 2Vpp output and MA12070 distorts the sound a little
- Class D
- Infineon MA12070 Class D
