I found everything except the LM3386TF. For those interested, here are the digikey parts:
311-220KCCT-ND RES 220K OHM 1/8W 1% 0805 SMD 0 0.04300
311-1.00KCCT-ND RES 1.00K OHM 1/8W 1% 0805 SMD 0 0.04300
311-8.20KCCT-ND RES 8.20K OHM 1/8W 1% 0805 SMD 0 0.04300
311-2.20KCCT-ND RES 2.20K OHM 1/8W 1% 0805 SMD 0 0.04300
311-18.0KCCT-ND RES 18.0K OHM 1/8W 1% 0805 SMD 0 0.04300
311-33.0KCCT-ND RES 33.0K OHM 1/8W 1% 0805 SMD 0 0.04300
P10.0FCT-ND RES 10 OHM 1/8W 1% 1206 SMD 0 0.06300
311-47.0KCCT-ND RES 47.0K OHM 1/8W 1% 0805 SMD 0 0.04300
CRH01CT-ND RECT SWITCHING 200V 1A 3-2A1A 0 0.44000
MUR820OS-ND RECTIFIER UFAST 200V 8A TO-220AB 0 0.80700
MUR3020PTFS-ND DIODE UFAST DL 15A 200V TO-218AC 0 1.77600
AD8620AR-ND IC OPAMP PREC JFET LN 8-SOIC 0 13.33000
LM317AEMPCT-ND IC ADJUSTABLE REG SOT-223 0 1.74000
LM337IMPCT-ND IC NEGATIVE ADJ 1A VREG SOT223 0 1.54000
PCF1489CT-ND CAP .1UF 100V PPS FILM 2820 5% 0 1.30800
PCC2005CT-ND CAP CERAMIC 2200PF 100V NP0 1206 0 0.44400
PCC1960CT-ND CAP CERAMIC 22PF 100V NP0 0805 0 0.10900
P10323-ND CAP 100UF 50V ELECT FC RADIAL 0 0.28000
311-1140-1-ND CAP .10UF 50V CERAMIC X7R 0805 0 0.09100
BC2076-ND CAP FILM MKP 1UF 63VDC 2% 0 0.99700
478-1395-1-ND CAP CERM .1UF 10% 50V X7R 0805 0 0.27500
EF6104-ND .1UF/630VDC METAL POLY CAP 0 0.63000
P5170-ND CAP 2200UF 35V ALUM LYTIC RADIAL 0 0.83100
493-1116-ND CAP 4700UF 50V ELECT VR RADIAL 0 2.64500
C1 is hard to get in Germany too. I've checked all big vendors.
(To name them: RS Components, Schuricht, Bürklin, Segor, Reichelt, Conrad). Did I leave one out?
Whats about Elfa to deliver to Germany ( better Western Europe,where they does'nt seem to be in business)? Any experencies?
Regards, Andreas
Regards, Andreas
Sorry,
forgot to say that Digikeys shipping costs to overseas seems nearly prohibitive to me. Handling and shipping exceeds alone the bill for P-A's PCB's, coils and shipping.
Fortunately I got the AD8620's from California via ebay from privat.
Incl. shipping less then 12 Euros, both of them. One piece is here around 16 Euros additional 5 for shipping.
So far it seems to make a lot sense to me to offer complete kits to get the builders going, open the package, heat the iron and have fun.
Its not really necessary to get 100 people doing the same job, hunting for the needed parts.
Again sorry, just my two (little bit frustrated) cents,
Andreas
Andreas
Otherwise, if Elfa delivers to Germany, who needs Digikey? (Ok, there are parts, that are not distributed in Europe at all, like Panasonic Microfoncapsules, which Linkwitz used)
I'll get in contact with Elfa, but just waiting for a while, if there won't be a german customer, who solved the problem by a local vendor.
And the choice of C1? Better to need none, so far it seems to be clear, but I want to take your design 'as it is', and that kind of capacitor is really hard to get, and nearly unknown to most people dealing with the elektroakustic business, as you wrote on yourself at another place. But I'll try hard...
Regards, Andreas
Regards, Andreas
peranders said:I'll guess the speed of building is a bit slow at the moment. Maybe people are getting parts?
I almost collect all the parts,some stuffs is on the road.
the PCB board is a little bigger than what I imagined,I prepare a big OEM case(483¡Á80¡Á340mm),see attached picture.I will finished it at the beginning of February.
Your boards has a killer look btw.
ZANG
I have start a thread to discuss assembly details.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=50473
ZANG
ZANG
One year has gone now. Just wondering about the building status?peranders said:I'll guess the speed of building is a bit slow at the moment. Maybe people are getting parts?
Its not forgotten, but...
First i want to wish a happy new year to you and your family, and all other people anyway. Specially to all those working for this site.
Unfortunately, last year wasn't for a very good friend of mine, just around that time of my last posting here it turned out that his cancer disease wouldn't be beaten.
But i never lost that project out of sight, and feel now ready to continue. Fortunately got assistance in professional handmade sm soldering techniques meanwhile, and won't be too ambitious in getting some 'hard too buy in germany' parts, such as special condensators from your partlist, just make it work the best way i can. ( But luckily, this special super dupa operational amplifiers was the last things i got bevor breaking).
My trust in the methodicalness of your design was never broken and it will proof.
Btw. are there any pcb's in stock to order?
Best regards,
Andeas
Best regards,
Andeas
- Group Buys
- Industrial SMD Gainclone - group buy
