I'm sorry, but the amp needs a zobel
The Zobel cap.
everyone seems to use res/cap/ground
This is generally how it is done. The reason is that it is better to ground one capacitor terminal to reduce possibility of any RF pick up on that. If the cap has a rolled foil , it might be better to ground the outer foil . Some larger caps have that indicated. With small caps you might be able to check that out with an external foil and a capacitance meter. I haven't tried that yet.
Cheers.
