You really should check your electrical code. The N.E.C. has an article (647) addressing this issue:
http://home.adelphia.net/~bethndave/nec647.jpg
http://home.adelphia.net/~bethndave/nec647a.jpg
It's only permitted in commercial or industrial occupancies 647.3(1).
Just so you know...
-Dave Curtis
Just so you know...
-Dave Curtis
I purchased one of the transformers Ken highlighted in his first post. The transformers are EI, input is wired for 240VAC, output is wired 120-0-120 with two output receptacles, one connected to each 120V leg + ground, capacitors are wired from the 120V outputs to ground + one extra wired with a series resistor taken from one of the 120V outputs to ground, and there appears to be no primary to secondary shielding.
The 120V secondaries are closely matched. I tested their voltages by plugging the unit into a 120VAC outlet and on 1-minute average readings from each secondary to ground read 60.71 and 60.72V respectively. L measurements of the secondaries to ground were both 437.1uH, showing closely balanced secondaries.
Thanks for the tip, Ken!
Hi all,
Recently I bought a cheap "multiformat" Samsung player (SMPS) to have a taste of SACD, whose sound was unknown to me. The player is noisy as you guess. I will try to improve it.
A few days ago I asked a local technician to wire a small (around 160VA) EI balanced transformer, with bifilar wound secondaries and electrostatic shielding. I connected it in "technical balanced" mode (with ground to "earth"). Powering the Samsung with it showed improved sonics (it still sounds like s****): less HF noise; more elegant sound; more detailed.
I also powered a CDPRO transport with it and it also showed a gain in resolution and flow. This transport has R-core Tx and ALWSR superregulated digital supply.
I added later a couple of Y-caps from secondaries to earth (10nF). While they cleaned up a little bit the highs, they seem to make midrange and bass lighter and colder
Just my impressions...
Regards.
M
Regards.
M
maxlorenz said:I also powered a CDPRO transport with it and it also showed a gain in resolution and flow. This transport has R-core Tx and ALWSR superregulated digital supply.
So much for DC supplies being DC, ey? They're all DC+, IME, the + being undesirable AC noizzze.
http://cgi.ebay.com/Controlled-Powe...ryZ16184QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/5-KVA-Power-Pur...yZ100184QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
There you go,a few units that can be converted to balanced AC
