McDark said:I also mean disconnecting IR2110's Vss from negative supply and tie it to the ground instead.
I think you need to update your knowledge...........You cannot connect VSS to GND incase of IR2110......
because the maximum permissible voltage difference VSS and COM terminal of IR2110 is +/-5V only.....
