UPDATE #62
1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 8A*1, 19A*1, 21A*1,23A*2
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 1A*1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 4A*1, 25A*1, 26A*1, 30A*1, 31A*2, 32A*1
37. NicMac 25A*1, 30A*1, 31A*1
38. szczemirek #25A*1, #30A*1, #33A*1, #1A*1
39. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
40. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
41. A123 1A (Q3)*1, 20A*1, 23A*2
42. _oxygen 1A (Q3)*1, 3A*1, 4A*1, 23A*2, 31A*2, 32A*1
43 minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
44. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
45. erikovsky 31A*1, 1A*1
46. JimS 25A*1, 26A*1, 30A*1
47. Studley. 25A*2
48. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
49. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
50. wealas 30A*1
51. linh0983 1A*1, 25A*1, 32A*1
52. Subbu K 25A*1, 26A*1, 30A*1
53. Karahana 3A*1, 4A*1, 6A*1
54. Patjr 27A*1 28A*4 29A*1
55. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
56. Jack0k 1A*1, 20A*1
57. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
58. Photochum1 25A*1, 31A*1, 23A*1, 13*3
59. AirAir 1A(Q3)*1, 20A*1
60. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
61. wcwc 1*1, 2*1, 13*22, 19*1
62. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 22*3
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
UPDATE #42
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
42. _oxygen 1A (Q3)*1, 4A*1, 23A*2, 32A*1, 33A*1
47. Studley. 25A*2
50. wealas 30A*1
Report Post Reply With Quote Multi-Quote This Message
Unread Yesterday, 05:40 AM #4102
twitchie is online now twitchie Canada
Magic Smoke Liberator
diyAudio Member
Ian asynchronous I2S and S/PDIF FIFO KIT group buy
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
diyAudio Member
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Sorry, Update #42 again
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Hope it's OK to ask here as I'm way behind the curve on this.
I currently have a RPI + Kali going into a single DDAC board. What would you recommed as a reasonably priced upgrade to the transport side of my system? I currently use Moode player to feed the system.
There are a lot of upgrades you can do:
I would change the raspberry pi for a usbridge signature from Allo to start.
You can use a better power supply for your rpi (or usbridge sig.) like the conditionerpi or UcConditioner.
You can buy a fifopi
You can upgrade the clocks of the fifopi for accusilicon or crystek clocks or even the ultimate Well tempered clock modules from Andrea Mori.
It all depend on how much money you want to spend.
@JCMcNeil was kind enough to post this link to help me get started / caught up:
For translation in your language, just check the translate option on the upper left of this page Na de succesvolle avonturen met de Allo Kali Reclocker in - BerryStreamer met Ian Canada FiFoPi
I noticed a cross correlation of the products you mentioned have similarities to products via the link.
I have to work within constraints. Small footprint as possible. LiFePO4 Single Battery powered FiFoPiQ3 transport. So I have to go Accusilicons at this time for this project. I'm new to all of this so it's a good start to get feet wet.
Otherwise, I would do everything possible to try to make Andrea Mori clocks work. I see it as saving money in the long run by bypassing the Accusilicons/Crysteks. It's something I look forward to down the line. I'm not into incremental upgrades as that cost more in the long run than just getting the ultimate the first time around.
If reasonable cost, you may only have a few weeks to get in on the current GB. I'm new so don't know, but it seems like with the Q3 release it may only be a matter of time before the Summer 2020 GB ends.
Thanks guys for the replies, much to think about. I will read up on the USbridge as I'm not too sure how it all fits in but I'm sure its an upgrade ove the Pi.
I assume it can be built in as another board to the DDDAC case I'm using making it all in one unit whch would be neat.
Another Question:
Do I still need to use the Kali between the UsBridge and the DAC?
Another Question:
Yes, kali is still recommended because the usbridge does generate the audio clock signal in the same way as the rpi and this is a high jitter clock signal.
The advantage of the usbridge is that the powerlines use all lineair regulators instead of noisy smps; result less noise. The board generates also less rfi.
Update where ID = "41"
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
41. A123 1A (Q3)*1, 20A*1, 21A*2, 23A*2
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
LinearPi Solo and Dual
Basically LinearPi Dual is two LinearPi Solo PCBs linked together.
They will be in special price when GB is open.
They are too thick to be shipped in a bubble envelope. Have to use a mailing box.
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
LinearPiSolo by Ian, on Flickr
LinearPiDual by Ian, on Flickr
Ian
Ian
A123 erased my line (post #4089) in its #4095!
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. nounouchet 26A*4
62. wcwc 1*1, 2*1, 13*22, 19*1
63. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 22*3
64. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
65. mnichols30030 25A*1, 27A*1, 33A*1, 34A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
== UPDATE cec @ row 63 ==
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 22*3
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. nounouchet 19A*1, 20A*1, 26A*4
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
I see FiFoPi Q3 updates are published and some great updates too
DocumentDownload/FifoPiQ3UltimateManualV3.0.pdf at master * iancanada/DocumentDownload * GitHub
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. cec 1A*4, 9A*3, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 13*12, 22*3
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
38. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
39. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
40. A123 1A (Q3)*1, 20A*1, 21A*2, 23A*2
41. _oxygen 1A (Q3)*1, 4A*1, 23A*2, 32A*1, 33A*1
42. minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
43. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
44. erikovsky 31A*1, 1A*1
45. JimS 25A*1, 26A*1, 30A*1
46. Studley. 25A*2
47. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
48. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
49. wealas 30A*1
50. linh0983 1A*1, 25A*1, 32A*1
51. Subbu K 25A*1, 26A*1, 30A*1
52. Karahana 3A*1, 4A*1, 6A*1
53. Patjr 27A*1 28A*4 29A*1
54. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
55. Jack0k 1A*1, 20A*1
56. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
57. Photochum1 25A*1, 31A*1, 23A*1, 13*3
58. AirAir 1A(Q3)*1, 20A*1
59. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
