1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 8A*1, 19A*1, 21A*1,23A*2
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 1A*1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 4A*1, 25A*1, 26A*1, 30A*1, 31A*2, 32A*1
37. NicMac 25A*1, 30A*1, 31A*1
38. szczemirek #25A*1, #30A*1, #33A*1, #1A*1
39. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
40. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
41. A123 1A (Q3)*1, 20A*1, 23A*1
42. _oxygen 1A (Q3)*1, 3A*1, 4A*1, 23A*2, 31A*2, 32A*1
43 minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
44. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
45. erikovsky 31A*1, 1A*1
46. JimS 25A*1, 26A*1, 30A*1
47. Studley. 25A*2
48. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
49. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
50. wealas 30A*1
51. linh0983 1A*1, 25A*1, 32A*1
52. Subbu K 25A*1, 26A*1, 30A*1
53. Karahana 3A*1, 4A*1, 6A*1
54. Patjr 27A*1 28A*4 29A*1
55. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
56. Jack0k 1A*1, 20A*1
57. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
58. Photochum1 25A*1, 31A*1, 23A*1, 13*3
59. AirAir 1A(Q3)*1, 20A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
60. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Ian, currently I am using RP3B+ with Volumio feeding my DAC via USB cable. My friend suggested a better transport because he said RP3B+ is noisy. And it is noisy comparing to my Vinyl. My vinyl has black background. So if I order 1A from you, do I need anything else? My DAC accepts SPDIF optical and Coaxial, BNC and USB. Greatly appreciated.
BridgePi
BridgePi is available now.
User's manual is here
DocumentDownload/Adapters/BridgePi at master * iancanada/DocumentDownload * GitHub
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
It's not expensive, but brings a lot new possibilities to the system such as native DSD, RPi free transport, and so on.
BridgePi by Ian, on Flickr
USBtransport by Ian, on Flickr
Ian
Ian
^^ +BridgePi (Simple USB Transport Version)
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
41. A123 1A (Q3)*1, 20A*2, 23A*2, 31A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Thanks Ian, I’ll wait for the FIFO Pi 3 and take your offer on the free PCB shield when I order the FOFOPi 3. Can you please put me down on the waiting list for it. Also, do I need anything else besides Fifopi3? Does it have its own clock and isolator?
I just order an Acopian regulated linear power supply rated at 5V 23A output (23A output not a typo) so hope it will clean up the power a little from Cana kit power supply
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. nounouchet 26A*4
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Ian, I'm trying to understand the ultracap possibilities for use with the Bridgepi. If I'm using bridgepi + amanero + fifopi with i2s out to an external dac and no rpi, can I power fifopi with 3.3v (thus bypassing the LDOs) or 5v uconditioner? Would the conditionerpi have a role to play anywhere in the stack? If so, which module would receive the conditioned power?
Normally, Amerno is USB powered. Is it possible to provide it with external power if using bridgepi?
Last question...if I add a rpi, can I use conditionerpi + 5v conditionerpi to power the rpi and fifopi?
Thanks.
Thanks.
@stew1234,
To use BridgePi and FifoPi without a RPi, basically you will need two power supplies, one is 5V before isolation and the other is the clean 3.3V, I have two options for you:
1. For a light weight application, use a ConditionerPi with a 3.3V LDO for both.
2. For advanced application, use a LinearPi Dual (5V + 3.3V configuration) and two UcConditioners (one 5V , one 3.3V)
Please let me know if you have more questions.
Good weekend.
Ian
Good weekend.
Ian
FifoPi Q3 + TransportPi would be a great combination for you.
Regards,
Ian
Ian, can you tell us what is new/different in FiFoPi Q3? (I still do not understand what exactly changed in Q2!)
Thanks.
FifoPi Q3 has a lot of improvements and new features. But the price will keep the same. I'll post the update very soon.
Regards,
Ian
Pass on BridgePi this time around. I was hoping to use 5V only.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
41. A123 1A (Q3)*1, 20A*1, 23A*2
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
@stew1234,
Good weekend.
Ian
Thanks Ian. I am still struggling to understand how everything would be connected:
In situation 1: I would feed ConditionerPi 5v, either from USB or higher quality supply via J9. ConditionerPi would output 5v and 3.3v. with the LDO. Is power then fed directly to FifoPi via GPIO? I'm not sure what is drawing the 5v and 3.3v here.
In situation 2: I would have 3.3v and 5v power supplies. I would feed FifoPi 3.3v to J5 bypassing its LDO and then 5v to BridgePi? I'm confused becuase the 5v input on BridgePi appears to be optional - would this feed Amanero external clean power so it's not USB powered?
BridgePi messing up the stack
Ian,
I have a strange situation, where once BridgePi is added to the stack (with or without RPi), The FifoPo stops locking. The various players I tried insist all is good and keep streaming data - just FifoPi is not locked.
When I first received BridgePi I had success with it on it’s own in the following formation:
Amanero (TPA version) -> BridgePi -> FifoPi -> TransportPi -> HDMI -> DAC. I tried PCM and all was great, but DSD (DoP) had a strange distortion to it.
I wanted to make sure RPi-> FifoPi was still OK, so I pulled the BridgePi from the stack and all was working fine again. I noticed I lost bass, which I dismissed as probably subjective at the time, but the more I listen to various tracks, the more I’m certain about it. Truth is, before adding BridgePi and ConditionerPi, my system never sounded so precise and full.
My golden stack was:
RPi -> FifoPi -> TransportPi -> HDMI -> DAC.
Even going back to it again, I can’t reach the same level as it was before adding the new components.
It could however be due to other variables - quality of mains etc - so I hope it’s not due to some glitch that the new components introduced.
Right now, the working combination is this:
RPi -> ConditionerPi -> ShieldPi -> FifoPi -> TransportPi -> HDMI -> DAC.
Apart from losing bass, I think I have bit of a buzz on quiet passages. I’m trying to get another DAC to eliminate as many variables as possible.
Today, I Decided to add BridgePi to the stack again - to see if it would play ball with RPi below it.
So the stack looks like:
RPi -> BrifgePi (Amanero TPA) -> ConditionerPi -> ShieldPi -> FifoPi -> TransportPi -> HDMI -> DAC
In both cases the players “see” the FifoPi as in they “agree” to stream, but I have no lock at the FifoPi. It is all PCM for now - I never try DSD first.
Any help would be appreciated. I have an oscilloscope and if you tell me where to look, I can troubleshoot.
Thanks!
P.S. I tried this combination and it worked:
BrifgePi (Amanero TPA) -> TransportPi -> HDMI -> DAC
It seems the FifoPi and BridgePi are not liking each other for some reason.
MCLK from BridgePi is now connected to TransportPi, while before, there was no connection from BridgePi MCLK and TransportPi was having MCLK from FifoPi.
Ian,
Thanks!
Ian,
Thanks!
Ian,
I also tried your default clocks - the 4x rate - I normally have 9x Accusilicon. Same thing.
I also tried flashing Amanero with SLAVE_1081_DSDSWAPPED and tried getting MCLK from FifoPi.
Same thing. No joy.
The most important thing I believe is that the EMPTY LED is not lit when BridgePi is connected.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. wcwc 1*1, 2*1, 13*22, 19*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
62. cec 1A*2, 9A*2, 11A*4, 12A*6, 20A*2, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 22*2
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
