jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x SMT XO Adapters KIT, 1x Finished FIFO Isolator Board, 3x SMT finished Battery Management KIT, 2x I2S to PCM converter, ##x U.FL Cables
nanocamp: pcm
lordvader : 1x I2S to PCM converter
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board.
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material
clsidxxl:1x finished Battery Management kit
nanocamp: pcm
Gogi x1 PCM board
My kit is gathering dust, so in case anybody is interested:
http://www.diyaudio.com/forums/swap-meet/247345-fs-ians-fifo-buffalo-iiise.html#post3735384
Totally confused
Most interested in this project, but coming in late.. I am completely confused.
What if anything is still open and available. I am running WaveIO / NOS TDA1541a. From reading, I think the ideal combination would be FIFO - Dual XO - I2S to PCB???
Is this correct?
Are all these GB closed? Are there new waiting lists. Where do I go next
Is this correct?
Hello to everyone!
Is it reasonable to use Twisted Pear Teleporter module between FIFO and DAC? I think about having universal digital signal receiver module with FIFO to work with different DACs. Does it make sense?
Regards,
mhgawel
The intended use of the fifo is to provide low jitter signals to the dac, so the ideal implementation is to connect it directly to the dac. Introducing hardware such as the Teleporter and cabling between the fifo and the dac will add jitter to the signals, which can undo the work of the fifo.
Thanks for the answer. I was afraid it is not a good idea...
nanocamp: pcm
Gogi x1 PCM board
kokonut : 1x I2S to PCM converter
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
casshan: 1 x I2S FIFO KIT v3.8, 1 x Dual XO Clock Board
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
fordgtlover: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x pkg Universal SMT XO Adapters
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
curryking: 10 x Dual XO clock board,5 x 6" double-ended U.FL coaxial cable,6 x package of universal SMT XO adapter kit
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
bisesik: 1x I2S to PCM converter
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
casshan: 1 x I2S FIFO KIT v3.8, 1 x Si570 Clock Board, 1 x Finished TPS7A4700 low noise regulator board V2.5
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
MadKid: 1 x TPS7A4700 low noise regulator, 1 x Universal SMT XO Adapters KIT
nanocamp: pcm
Gogi x1 PCM board
Waiting list
Hi Ian,
Loving this project, just what I'm looking for. Excellent work.
If I add myself to the FIFO waiting list for a possible GBVI, do you want the order form sent straight away as well? Or should I wait until you confirm that GBVI is going ahead?
Thanks very much
Dan
Hi Ian,
Thanks very much
Dan
nanocamp: pcm
Gogi x1 PCM board
dant100: 1x I2S FIFO kit, 1x Dual XO Clock Board, 1x Pack of SMT XO Adapters, 1x Finished FIFO isolator board, 1x Finished TPS7A4700 Regulator board, 1x Finished Battery management board
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
Phi: 5x I2S FIFO kit, 3x Dual XO Clock Board, 3x Pack of SMT XO Adapters, 5x Finished FIFO isolator board, 5x Finished TPS7A4700 Regulator board, 2x Finished Battery management board , 5x I2S to PCM converter, 1 x Si570 Clock Board (at least this)
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
zz1969: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
