Please add your ID to the waiting list if you are interested in next GB. Or, please remove your ID if I put it with wrong
jbercovici : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700
malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
LOBOONE: PCM, 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board
Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
Ian
Isn't it better to start a new thread for GBVI- its's so hard to find the start... ?
Ian FIFO and PCM board GBVI waiting list
roger57: 1x I2S FIFO KIT V3.80
mhgawel: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x SMT XO Adapters KIT, 1x Finished FIFO Isolator Board, 1x Finished TPS7A4700 regulator or 1x SMT finished Battery Management KIT, 1x I2S to PCM converter, ##x U.FL Cables
nanocamp: pcm
nanocamp: pcm
nanocamp: pcm
lordvader : 1x I2S to PCM converter
nanocamp: pcm
Received!
Hi Ian,
Many thanks for speeeeeeeeeedy service. Received the I2S to PCM PCB, and S/PDIF input board.
I just paid 2 days ago...and received it today. How do you juggle it all and find time to eat and sleep?? Amazing.
Hopefully the next round of FIFO GB will happen soon...
Gary
Hi Ian,
Gary
mhgawel: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x I2S backdoor KIT, 1x SMT XO Adapters KIT, 1x Finished FIFO Isolator Board, 3x SMT finished Battery Management KIT, 2x I2S to PCM converter, ##x U.FL Cables
nanocamp: pcm
nanocamp: pcm
Hi Ian,
Gary
Because you are in Canada
Good to know that, have a great weekend.
Ian
Ian
Ian,
Wrong thread, but just a quick question: is there a significant difference (by you or reported) in actual (or perceived) sound in using the I2S to PCM PCB, over the original version FIFO and re-clock PCB? (as I have now)
This would be with respect to the TDA1541 running NOS.
Thanks,
Gary
Hi Ian,
Returned from vacation and found GBVFIF073 in my mailbox.
Thank you.
Ben
Ian,
Today I received everything, thank you very much for your quick delivery and excellent work !!!
Saludos y gracias,
Manuel
Good to know that. Enjoy your project. Get back to me if you need any support.
Regards,
Ian
Hi all
first post in this thread, been reading ecdesigns ultimate tda thread and am about to use 2 red baron v5's to do dual mono tda1541a.
question 1) which of ian's boards would i need to go from spdif optical ( + coax), and use dual mono mode. i only need 44.1 kHz so don't think i need two clock board.
question 2) is there anywhere i can get this info quickly without reading this long thread all the way through ?
thank you all for any help and congratulations to ian for all is impressive work and time
james
james
nanocamp: pcm
flowerpot: 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x Finished FIFO Isolator Board.
nanocamp: pcm
nanocamp: pcm
4me2ctv : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x pkg Universal SMT XO Adapters, 1 x I2S backdoor kit, 1 x finished TPS7A4700 regulator
nanocamp: pcm
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
nanocamp: pcm
Gogi x1 PCM board
JustBuildLspkAS x4 finished FIFO i2s isolator Board , x2 Si570 Clock Board V3.5(with Si570) to play 24/384 Material
nanocamp: pcm
Gogi x1 PCM board
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
