Hypex Ncore
Hi ti33er I believe your tweeter is a Fountec CD3 which I use extensively in my Speakers, its pretty wonderful.
Hi Colin
I believe it is based on this Fountec CD3, but had some tweaks done to get it from 40Khz up to 100Khz (as JULF said my pet Bat may appreciate it more than me) :)
To be honest, I still find it a bit shrill - the top end has a metallic hardness to it, even though Reviews will inform you that its silky smooth without a hint of harshness!!!
I am blaming my Source equipment (currently OPPO BDP-105D and previously my TAG McLaren AV32R DP which sound about the same) and TAG Amplifiers - heresay that these Monitor Audio PL200 really shine with a good TUBE / VALVE Amplifier ...I did a bit of research, which led me to these nCore Amplifiers with the claim of VALVE treble qualities... lets hope this IS the case :-D
Paul
PS. I really wanted some MartinLogan ESL speakers (like Summit) or Magnepan 1.7i as the Image on diPole is just undeniably better than any box speakers I have listened to...but they are too tall, like 1.5m and higher which get in the way of my Cinema Projection screen :-(
Thanks! It is not very comprehensive (compare to TI, who even provide a Spice model for their opamps), but while I can't spot any hugely major incompatibilities (the obvious ones are input offset and bias currents that are 7000 and 3000 times as large on the Burson) , I do notice that the LM4562 has generally better specs.
With the BURSON implementation in the Input Buffer, should the LM4562 prove to 'sound' better, there is always the DIP-8 version to revert to and also the HA LME49720 LME49720 | Audio Operational Amplifier | Operational Amplifier (Op Amp) | Description & parametrics which is the Military shielded version being pedantic, so nothing lost (if nothing gained)
Just to elaborate a bit - in the case of the ncore amps, being class D, they have to have a low pass filtering function to avoid aliasing, so anything above 200 kHz or so will be cut off by the power amp, but might still cause intermodulation. Thus the oscilloscope should be connected to the opamp output (where it is easier to see the oscillation anyway, as the switching noise will make the scope picture messier on the ncore output).
Oscillation between 20 kHz and 100 kHz might still make it out of your tweeter, and annoy your dog or pet bat (named Eric).
Are you saying this will cause damage or just annoy pets
Seems consensus with these nCore Amplifiers has been "...they got the treble right" / "...competes with good Valve" / "...clean"
Consensus, or groupthink? :)
In my experience, valve amps are seldom the most clean and transparent (in the sense of "least distortion and colouring").
Do you think these Amplifiers might make my Ribbons harsher !?
If the ribbons sound harsh with a neutral amp, and softer with an amp that has a gentle treble rol-loff, then yes, quite possibly.
Re military spec IC's in a high % of applications they are identical components that have been tested and passed at the extremities of there operational window. I.e. Frequencies, temperatures, noise etc. I worked for a semiconductor testing solution company dealing with Plessey, Marconi, ATT, Motorola etc it was a while ago as many of these great names don't exist today.
Hi Boggit
Being dead honest, 'we' couldn't hear the difference between the standard and military spec versions.... We had to bend/shape the pins with long nose pliers to make them fit into the DIP-8 sockets and they ended up looking like funky spiders :)
They did look quite cool nonetheless
BR
Precisely. My quip about mil-spec components sound harsher and harder was targeted at the projectionist school of audiophiles ("silver cables sound bright, digital sounds sharp like it had steps").
Indeed. The names are gone, and some of the activities have been carried on in their successors/new owners. Racal and Decca disappeared into Thales, Plessey into BAE, ATT (as an equipment manufacturer) just became part of Nokia. I guess the semiconductor part of Motorola is the one that has survived the best, as Freescale.
Hi Boggit
BR
In which application did you try them in? You didn't mention that earlier.
Hi Colin
Paul
Don't ever expect an Ncore amp with any buffer stage makeup for weak source gear. You should probably deal with that. The Mirand DAC on the other thread would deal with that problem for low cost. With the DAC/pre combo in the new case he's building, you can drive the NC500's direct with no buffers. Sounds stunning.
:) I am waiting (patiently, sometimes less) for John Westlake's FDAC! ...it's supposedly, going to be the best DAC yet ...we can choose MOSFETs option which he thinks will be less 'hard' sounding than transistor option, but slightly less THD/Dynamic Range, aimed for as the highest spec in the Industry (currently) IIRC
Best selling point for me re the FDAC is the 'AV Bypass' because my Cinema/2-Channel is integrated with my Loudspeakers
I realize I'm a little late to the party here, dashed over from WBF where Blizzard's been holding forth on the advantages of active systems... Excellent seeing all the roaches over there running for cover :)
It was most likely clipping at high output. It just didn't sound as good when it was flat out. Much better with the additional buffer stage in the path.
Based on my experience it won't have been clipping methinks. I'll be the switching noise generated on the supply rails because opamps have classAB output stages. You can try an experiment - fit a current source to the -ve rail on the outputs of your LM4562s, magnitude equal to the maximum output current required by the input of the nCore. The CCS can just be a couple of cheap bipolar transistors (BC547B works fine).
It was just an experiment anyways. I was running it direct, bypassing the LM4562 buffer, which was why it was working so hard.
I'm not doing it anymore, it was just a test.
