Dear see the previous post I was upload circuit digram . Dear if I connect multiple circuit in one transformer then create ground loop but here this single circuit connected to transformer
But this circuit come out noice .
That circuit diagram doesn't show the whole unit, the signal path from audio input to output, how the power supply is wired and connected to the rest of the unit, everything. That's what is needed to help you. Ground loops can be caused internally or externally to the unit, or both.
Mike
- Chip Amps
- Humming Noise in my amplifier???
