Hum&Buzz problems DIY CE pre-amp
Hi everybody,
I am a musician and I want to start building some pedal effects, pre-amplifier, filters and so on. Just for hobby :)
My target is to learn starting from descrete components (I think it is the most basic level, isn't it?), so my first project is to build a simple pre-amp using a transistor in a CE set-up.
I was experiecing some buzz/hum problems with my CE amp. Since I want to learn, I attach a detail report and two recordered audio instead of write here.
At the end of the report there are my questions :)
I hope this is the right way to explain to the comunity my troubles and I hope this will be helpful to somebody.
Thank you
Andrea
  • Report Test.zip
Looks like radio frequency ( RF ) pickup . Try putting a 1K resistor in series with the input and directly after put a 470pF capacitor to ground to form an RF filter with an approximate turnover frequency of 338 KHz .
PS just read your info in more detail . I had missed the point where you say plugging the pickup directly into the Focusrite also gives hum/buzz . Maybe there is also an earthing issue .
Thank you epicyclic.
One important note: my pickup is a Shadow SH330 which is a SINGLE COIL pickup. Maybe, it picks 50Hz hum from electrical house circuit.
I suppose this because:
  • if I move around there are some points where the hum lower a lot (never svanish anyway)
  • I tried to build the second stage of my project using an emitter-follower amp...and it actually works! I can hear sound from my guitar using headphone. I powered-on the circuit (CE-CC cascade) with a 9V battery. The hum remains, and again if I move around the hum level change.
I think that I cannot do anything with a single coil :(
Howerer, I have two other questions if I do not bore you...
1. If I use a battery, I do not have a ground, right? I mean, the 0V battery is my reference, but I don't have any proper ground. Is it correct?
2. My test configuration was the following. I hear from both sides of the headphone. However, I did not plug the ground. Are there some corrections to do?
ps: it was quite surprising for me that just 1mW rms signal on my headphone is sufficent to hear a lot!
Thak you very much for the replay.
So for point (2), if I understood correctly, I should do that...
For Balance/Unbalance: again, if I understood correctly, balance cables have a shield. However, a shield must be connected to a proper ground for working corretly. Does the following scheme make sense? The proper "ground" is the ground of my house connections I think (I am a little bit scared to do that ahah).
A note: I tried to input my mobile phone instead of guitar pick-up. No hum/buzz is present powering the circuit with a battery. I don't have humbacker pickups to confirm that noise is coming from the pickups :(
You speak about "grounding loop" problems...what do you mean?
Andrea
An ordinary twisted pair of wires is balanced , each wire has the same resistance , capacitance and inductance . A balanced connection has to maintain that balance by terminating the each wire with the same impedance both at the transmitting and receiving ends . Having a grounded screen not necessarily an earthed screen round the pair helps to reduce interference . Balanced microphone cable has a twisted pair with an outer screen . Standard coaxial cable has a single inner wire with an outer screen and thus by design is unbalanced .
I would not advise making the house ground connection .
You did not say if you have input 2 of the Focusrite set to instrument or line .
You have not said if you tried the RF filter suggestion .
Another thing you can try or not try is to limit the low frequency response of your circuit as an ordinary acoustic guitars lower register doesn't go that low . Put a 2k2 resistor in series with the input and change the input capacitor C1 to 220nF . this will give an LF roll off starting at approximately 328Hz .
Suggestion ..... start another thread in " instruments and amps " and ask if others have had the same problem as you using the Removable Shadow Acoustic single coil pickup directly into a Focusrite Solo 2nd gen and laptop .
A cable shield/screen should be attached to a metal chassis at its connector. While a shield will probably have continuity to 'ground', the shield is not part of the 'ground' system or systems.
Note that the Safety Ground/Protective Earth is one 'ground' system and the ground rod/Planet Earth is another 'ground' system.
Note that the connection to Planet Earth is there for safety during unusual high voltage events. It has little to do with day-to-day AC power quality or audio system quality.
Apologies , brain fart , omit the 2k2 resistor and change C1 to 4.7nF .
