Yes,The drain pin of the mosfet is connected to the metal tag and has very little thermal impedance that is to me the best place where to stick them, adhesive or tie wrap the key is low thermal impedance
that's where the heat of the junction can be monitored fastest.
bksabath said:The drain pin of the mosfet is conected to the metal tag and has very litle thermal impedance thath is to me the best place where to stick them adesive or tie wrap the key is low thermal impedence
Aha!! That's why the thermistor is placed there on the factory-built F5! I have been scratching my head, wondering why the thermistor looks like it's too short...
Specifically, these are the photos that I am referencing -- (from 6moons.com)
http://www.6moons.com/audioreviews/firstwatt7/f5_2.html
Scroll down a little, you will see 2 pics with the output transistor and thermistor clearly visible.
can you recommend an metal epoxy?
I was looking at j-b weld, but it's hard to find.
Try a good auto parts store, if none local try online. That stuff has been very useful for a variety of apps and a lifesaver in others many times in the past; last time I looked they offered both a fast cure and slower cure version...
LePage Epoxy Steel is what I have used before. It contains metal, it can be sanded/worked after setting and isn't supposed to expand or contract. It won't be as strong as having things screwed down, but for a single PCB standoff, it should be just fine.
Products - LePage for Canada
You can get it at most local hardware stores for less than $8, probably less than $7.
Arctic Silver has a couple products which are two part adhesives. They look interesting, although I haven't tried them.
Arctic Silver, Inc. - Arctic Alumina Thermal Adhesive
Arctic Silver, Inc. - Arctic Silver Thermal Adhesive
I was thinking epoxy to tranny body but middle pin makes more sense. I have switching p/s that have a thermistor on the heatsink glued to a small metal eyelet then screwed to the heatsink next to the trannies it looks at .
I would think either would be OK but faster response to the middle pin.
OIC,Elwood
OIC,Elwood
The Credit Card issuer has an enormous effect on the retailer's sales.
As soon as you have the Credit Card on your side, the retailer gives in.
Reporting through PayPal is the first warning that the retailer gets that you mean business and expected to be treated as a valued customer.
By opening up a case with paypal, and applying a little bit of pressure, HIFI 2000 is sending out a new heat sink.
Good result
Just out of curiosity, are they asking you to return the damaged one? (If not, it would be a great addition to your parts bin!)
Quote > By opening up a case with paypal, and applying a little bit of pressure, HIFI 2000 is sending out a new heat sink.
Realy made up for you
Got a few more pictures of my build.
A drill press would realy help but does not fit in the loft and to much noise.
The main frame is done so time to get started with the Circuit boards
Soft start and Aux suply From print to etched board in less than 30 minutes.
No picture for the back plate I got al the holes drilled and started to paint (mess it up I mean )
I realy realy hate painting
Everything is aluminum, isn't it? Have you considered anodizing it all?
That said, thanks so very much for posting more photos! Keep 'em coming!
- How to build the F5
