nothing is wrong.
The original value was 200ufd.
The later value with the Medallion xfmrs was 47ufd.
I seem to recall that there was a very small difference in the turns ration with the Medallion - I suspect it was a change to permalloy or another better grade of lam that is/was the main diff.
You can play with that value - but keep in mind that the xfrmrs response OVERLAPS by several OCTAVES! It's not a standard xover!!
The simplest thing is to just change it to whatever your stock value is... of course it is best if both channels happen to be the same!
_-_-bear
_-_-bear
Hmm..., I changed the 220 electrolytic caps to 47uF Solen metalized polypropylene film caps. After a couple of days of running, I find it's smoother, less glare, and warmer sounding. However, it appears to be closed in, slower, less detailed and extended than before, basically lifeless. What's wrong? Is it because of the value used (47 vs 220) or the characteristic of Solen caps? Any recommendation?
- Planars & Exotics
- how do i know if my hf on my acoustat 2+2 are the same level?
