I will make the demo/sample board soon, will post the photo then.when will this be available?
Looking good. I have an Audio-gd DAC that swaps out a DIR9001 receiver or a Wolfson. The DIR9001 is clearly better in that DAC. Have you all considered using it? This looks to be a very fun project. How many amps will the 9V power supplies need? Any plans for some nice power supply boards to go along with the DAC? I have been wanting toi build a supper integrated and I see the HiFiMe products lending themselves very well to that project.
I think WM8805 and DIR9001 are at same level, both have very low jitter. We will start with WM8805 first because I used this chip before and it's good. About 10VA PSU is ok for this DAC. And actually I'm thinking about a PSU for DAC, use a on board transformer, hope it will start at the end of this month.
Any photos?
Is this transformer a good option? 115V/230V 40W Audio R-Core Transformer 9V-0-9V 9V*3 | eBay
I think it's ok.
...have you considered the module concept like what twisted pear is doing with their Buffalo III DAC? let users have the option of using their preferred PSU like
Sala's SSR1.1 BiB shunt reg
http://www.diyaudio.com/forums/group-buys/188974-gb-thread-salas-ssr1-1-bib-shunt-reg.html
I don't think so. DA-X0 support different DAC chips by changing module, and support TCXO on board. It doesn't have analog buffer, so make power supply very simple(easy to use).
update
Hi all. I test the cox input today, and set CS8421 to output 96kHz, it's not bad, but when I set it 192kHz, the music sound discontinuous. Also when 44.1kHz signal input, there will be some noise on output because I'm using 24.576Mhz OSC for up-sampling. And all problem is gone when CS8421 is bypassed. In general, I think it will be a good DAC. I will do more work to make it better later.
I will receive a first working sample in a few days, looking forward to try this DAC !
Thanks to everybody for feedback and advice.
This DAC will be possible to make in different versions, with/without TE7022 USB, with/without CS8421 upsampling, and with/without TCXO oscillator. This board can also be used with different DAC's (voltage output only) but we'll start with CS4398.
- Digital Line Level
- Hifimediy direct out cs4398 DAC
