I found pin 3 of IR21844 on the right disconnected. Can this be the cause of non seeing square wave on the other pads?
EDIT:On 4 of 8 gate pad I see square wave at -85 Vdc. On the other 4 I see only a little Spike (about 200 mV). It's Correct (outputs are out of the board)
Noise is come back, also without RCA jack insert. Sometimes is very very high and the amp goes into protect. Sometimes (when is very very high) I hear it coming from relais or capacitors. What can be?
This is when is low....
https://www.youtube.com/watch?v=QinL2gQ3QsA&list=UULCD3dzxU85s74safPk3usg
- General Interest
- Car Audio
- Hertz HP1D problems
