One also needs to consider that this is the perfect setting to get exposure for his magical product. Seems strange that a NEW member has a snake oil product and is in the process of possibly getting ripped off. Some here actually believe in the make believe connectors, speaker line, and interconnects so why not a power cord. How many are ready to sign up to purchase one?
I have a power strip with American outlets. I also have adapters.How did you test a cord with an American plug in your system in Europe?
I have been experimenting with American cables for a decade without any problems. But in my system I don't have any tubes.
Well, just say that you want your cable back so you can see what's wrong with it. If he sends it back, be happy and ignore him. If he doesn't, ignore him anyways.
As everybody else has said, your cable is not the fault and he's the douche thinking a new cable will improve his sound.
I think it is pretty clear that the group here agrees that there is NO WAY for this, or really any US system power cable to damage anything downstream.
I think it is hard to even imagine it would blow the fuse in the amp, much less damage a tube.
Perhaps you should share the the of the publisher for this reviewer. I would certainly shy away from a magazine employing fools as their "experts".
Please also, let's not disparage the OP for his small and perhaps fledgling cable business. Some folks like aftermarket cables for a variety of reasons. Besides, the OP has not actually made any unrealistic claims as to his cable's performance here, nor has he made any underhanded efforts to sell or advertise.
Tell him his house wiring isn't up to the task of supplying audiophile power. All your power cable did was reveal the house wiring deficiencies by allowing them to pass through to his amp.
He obviously needs a house wiring upgrade. A service you can provide for a plane ticket for you and your assistant , and a of course a small , but higher fee than $641. You will refund his money by taking $641 dollars off his bill.
If that doesn't work, tell him his amp couldn't simlpy go on living, after having its new pure electron supplier taken away.
Completely agree and thank you for putting it so eloquently.
Should I tell him to try my cable another time or should he send it back to me so I can inspect it?I think it is pretty clear that the group here agrees that there is NO WAY for this, or really any US system power cable to damage anything downstream.
No!
Yes!
I see it is now posted elsewhere:
DIY Audio Projects Forum • Help! Did my power cable blow his tubes?
Something puzzles me: how is it that someone who knows enough to design and construct a 'superior' mains cable does not know enough to make a judgement about its alleged damaging effect on an amplifier, so requests help on two different DIY sites? Has the same question been asked on professional electricians' sites too?
I told him from the beginning that it's not possible that a power cable could blow his fuse, but he keeps disagreeing with me so that I start to doubt and worry. If I had known that power cables could destroy amps, I would never have risked sending cables to anyone. I have sent cables to many people and they never complained.Something puzzles me: how is it that someone who knows enough to design and construct a 'superior' mains cable does not know enough to make a judgement about its alleged damaging effect on an amplifier, so requests help on two different DIY sites? Has the same question been asked on professional electricians' sites too?
Could his fuse have blown if my 15awg cable was too thin?
In Europe you can use thin cables for high watts because you use both the live and neutral conductors, but in USA you use only the live conductor to supply the power, so you need thicker conductors, correct?
If my cable was too thin, the insulation would have melted?
Here are the specs of his amp:
Specifications
Amplifier
Ayon Triton III
Class of Operation
Triode* or Pentode mode, Class-A*
Tube Complement
8 x KT88
Load Impedance
4 & 8 Ohms
Bandwidth
8Hz-70kHz
Output Powerentode mode KT88
2 x 100 W
Output Power:Triode mode KT88
2 x 60 W
Frequency Response
10 Hz - 60 kHz
Input Impedance at 1 kHz
100 KΩ
Input sensitivity (full power)
1V
NFB
0dB
Remote Control
Yes
Inputs
3 x Line IN, 1 x XLR IN, 1 x Direct IN,
Outputs
1 x Pre Out
Dimensions (WxDxH) cm
51x42x25 cm
Weight
45 kg
We use live and neutral here too, you have to complete the circuit. The reason smaller gauges are used in Europe is because the line voltage is twice as high and current half as much for a given power level compared to here. In any event 15ga wire should be sufficient for roughly 10A.
- Tubes / Valves
- Help! Did my power cable blow his tubes?
