Audiophile's have these short of mid life crisis ocasssionally.
Mert has appeared in 12 threads over the past 4 months and to be searching for something. But his system has changed. Particularly the loudspeaker which were previousy Focal when he acquired the X250.5.
http://www.diyaudio.com/forums/showthread.php?postid=1083593#post1083593
"4) despite quite low volume levels that I apply, your amp sounds more powerfull than Musical Fidelity kw 500 integrated which is almost 500 watt in 8 ohms? interesting, isn' t it? maybe your amp works pure class a for first 35 watts or more?
5) Do you like music as well designing amplifiers?"
http://www.diyaudio.com/forums/showthread.php?s=&threadid=107402
http://www.diyaudio.com/forums/showthread.php?postid=1132019#post1132019
If mert can find an AX160 he may like it as it was reviewed well with Wilsons
http://www.passlabs.com/pdf/reviews/poltun-xa160.pdf
iMac
iMac
Too many positive inputs. Thanks folks. I have clarify a few points:
Before having bought Boulder 810, I had also Pass X2.5 on hand and had chance to compare all Boulder and Pass Labs.(1010,2010,810, 2.5,x1,x0.1, x1) I loved 810 most and bought it. I could have bought 1010 but it has been long in market and most likely to be dropped soon from production. 2010 is a very good indeed but has to be paired with top of the top power amplifiers. Pass preamps have a interesting synergy together with pass power amps but I prefer Boulder and this is subjective.
If I had enough space I would go to XA100.5 or 600.5. I like Pass Sound and prefer over Boulder Power amps(1060,850) and Gryphon Range.
IMO, Currently Nelson Pass number 1 amp maker/designer in USA and makes best power amps in the States.
If I have to get another brand it will not be from States it will be from Japan.(Accuphase A-60 or P-7100)
I am satisfied with X250.5 and don't want to change to something which will not yield very very marginal benefit(sonic)
Thats why I would like to make something very very good ''perfect''.
I just wanted to learn either there is a possibility of mod. or Not.
[/IMG]
I have changed my racks as I said I was gonna change soon.
[/IMG]
Guess which combination gave me most pleasure?
I mostly find the PEH169's from guys with an A40 or A75 project that never realised, so mostly "never used old stock". Since I have what I can absorbe myself, I will get back to you next time I stumble over some. I realise that you had more than a finger in the A-X board design I (we!) owe you one, and this could be it. The PEH200 series is readily available here in Scandinavia. The prices are pretty heavy though.... A 100.000uF/ 63 V is about 150$ give or take... You would need 8 pieces for monoblocks with a CLC supply like I favour (as in the pic's). The 40V's are a "lot" cheaper Approx 80$.grataku said:Hey guys!
those are some schweet pics!
Steenoe,
those are my kind of heatsinks AND caps! I briefly looked for Rifa in the US a few years back, here they go by Aerovox and it's not the same stuff. Anyways I could never find the supplier. Where do you get yours?
I realise that this is totally OT, but what....
steenoe said:give or take
Steen,
be gratefull you were fishing a couple of decades ago.
.50 caliber capacitors have become relatively affordable, compared to the early Pass/Thagard et al design days.
