Hammond SE Transformer question
I have just build my first tube amp and i was designing a nice rosewood box for it when i found my output transformer was just too big for this little amp- my mistake. I wanted to do a little and cute box.... The trafo is a hammond 125ESE. I have seen the smallest of the SE line rating 3W really cheap (Hammond ASE) and as my amp puts out 2w am thinking of buying it and use the ESE(15w) for a guitar amp(the amp i made is too clean for electric guitar).
My question is this: will i miss something in the sound?
I am happy with its sound but i plan to make another amp with some Russian valves i saw in the future. Will i repent if i replace the transformer? If somebody tells me the sound would change for worse i would not do it.
I'm not an audiophile but my ears are not fooled easily.
So long as the primary resistance and the secondary taps are correct it should be fine. I think as far as transformers go, all other things being equal, the smaller they are the better the frequency response will be, though I dont know if this will be noticable. If it's rated 3W, has the right primary resistance and the right secondary taps, and is cheap, Id go for it. If you decide you dont like it you can always swap it back as you say you can get them cheap :)
I'm a beginner myself so dont take any of this as fact!! I'd wait to see what everyone else has to say on it...
Good luck,
Steve
Big sound needs big iron due to high power, or the transformer would get too hot. In the case of single ended amps they also have to cope with higher DC flow on the primaries. Your amp is 2W and using a huge opt won't change that.
Just googled for that transformer and apparently the 125ESE can cope with 80mA DC on its primaries and is more suited to single ended KT88 kind of power, which seems a little overkill. I think you should go with the ASE :)
Steve
fdegrove said:
At what end of the spectrum?
There's alot more than physical size to a good OPT but you just can't get any decent low frequency response out of a miniature sized one...
I was on about losing top end with really big opt. Im just quoting out of Morgan Jones's book here, I haven't any actual experience apart from the amp I just built. I remember seeing on the sowter site some frequency response curves for their opt, maybe hammond do the same?
Steve
I just thought if the 125ESE sounds good and doesn't even get warm why not try the ASE?, not really because is cheaper but because is smaller...anyway why the OT should be that big for only 2 watts?...i feel like i am wasting the transformer....off to the guitar amp:)
Now i need a good schematic for a guitar amp.
Cheers
i have decided what to do...i will go for the smaller...will post if results are poor. I don't think so.
Thanks for the help
125ESE
Hi! I've made my PCL86 SE with the Hammond 125ESE transformers. Response isn't flat in the low end, there sure is some drop. I don't have any spectrum analyzer, have tested with test CD. With my Fostex FE206E in a BL horns it doesn't bother, cause the f0 is ~50Hz...
-Pete
Morgan Jones at the book "Valve Amplifiers" says that output transformers for guitar are deliberately poor (at the chapter "Guitar amplifiers and arcs"). Maybe they do this not only to economize in price and weight, but also to get more "tone" (bluesy distortion).
This thread also talks about transformers for single end amps.
Manuel
Hi Manuel:
That makes sense...i've read that Matchless made a famous amplifier line starting with just one excellent transformer they got from an amp with great tone. They duplicated it and made a design for it so i guess OT are vital for the right guitar tone.
Cheers
Alvaro
Hi Alvaro,
the first impression was that there is a lot of highs compared to mids and bass. Cannot tell anymore..:rolleyes:
I added some caps to the amp to reduce hum. I think the sound is now too "dry/airless". Have to adjust the filtering cap values.
Overall the amp sounds better than I expected.
