Shame you can't get the (is it volume or selector)
Shaft cut a bit shorter so the knob covers the nut without scraping the chassis,,there a pig to cut without a vice to hold the shaft. I mark the shaft with tape so I get a flat cut across the shaft. It gives a guide line.
Good luck with the mods
M. Gregg
M. Gregg
Shame
Yes, it's on my to-do list. A PITA because it comes soldered to a PCB (remote). Not happy with the pot either .
I cut with a small hacksaw..
You have to measure the length a couple of times and cut once (no mistakes)
Also if you cut it take your time sometimes the heat from the cut can damage the track inside the pot.
I used to cut freehand ..LOL..I now use tape to mark the line for the cut after having to file the end to get it straight..not so bad if its a plastic shaft..
It does make the project look better...however if its on a circuit board its a difficult choice..
M. Gregg
M. Gregg
Yes Dremel,
I use mine alot...it does generate some heat so you have to go bit at a time..If the shaft is metal it heats the inside of the pot so I let it cool and cut again..
The main thing is getting the measurement right first time..
Some people rush it and scrap the pot..LOL
M. Gregg
M. Gregg
- Tubes / Valves
- Goodcomponent - another chinese supplier
