Do you have power supply boards?
Yes, but not as many as M2c boards.
hi Tea,
I'd like to sign up for 1 set of stereo M2C boards, Output mosfet and a pair of Edcor Transformers. I don't need PS board since I had my own PS setup already.
You can PM me with the total and paypal email. I will transfer the money.
Thanks,
Tom
Signed you up. I Will private message everyone once the Edcors arrive.
Thank you Tea
I have the M2c boards, power supply boards (a couple)
Edcor transformers and the Vishay/Harris mosfet combo currently in stock. PM with email address if interested.
Teabag, I have sent you PM message.
Thanks,
Tom
Thanks,
Tom
Hi Tom, I did not get it. Can you try again?
Hi tea,
I just resent my message. Can you check and reply me in PM ?
Thanks,
Tom
Thanks,
Tom
I’d like to order the audio boards and PSU board. Can you send an invoice to my email?
I only have the audio boards and the Edcor transformers in stock right now. Did you want to proceed with those?
PSU are currently out of stock.
I think they will be fine, that is what I used for a range. If they run too hot - the Jfets, you could change the 10R source resistors to 15-20R to draw a little less current.
With reference to this post, where to measure if JFETs are running hot/or not? The ones that I plan to use have IDSS of 10.7 mA.
Hi ZMAN,
I am not the best in calculations and assumptions, but if Ohms law is fully in play.
11ma @ 24v without Source resistor is .264ma so a bit more than half of 400ma max. probably want to be more around half max, so 200 ma, so I think a 10-20R resistor is would cut this back.
In my experience high idss JFETs are fine if source resistor is tuned good. Otherwise when they run too much juice through them they run more unstable, making sometimes the other end of the circuit a bit more wild to stabilize.
Salas and I ran into that with prototypes of the Folded RIAA, until we ironed out a few elements.
BTW, I have run 10.5ma ones for probably two years in mine without any issues. I listen to it alot, as it's in my work office.
- Group Buys
- GB Pass M2 Clone Boards with 120mm UMS spacing by Tea-Bag
